Any changes
30 Dec 2011
Essex
I have spent some time on designing this and I know they are all compatible together. But I was wondering whether someone might have a better idea. I wish it to be in a similar budget range.
EDIT: Asus P8Z68-V PRO/GEN3, Intel Z68, S 1155, DDR3, SATA III - 6Gb/s, SATA RAID, PCIe 3.0 (x16), D-Sub/DVI-D/HDMI, ATX
Corsair CMPSU-850HXUK HX 850W Modular Power Supply (PSU)
Intel Core i5 2500K Unlocked, S1155, Sndy Bridge, Quad, 3.3GHz, HD3000 IGP 850Mhz, 6MB Cache 95W Retail
8GB (2x4GB) Corsair DDR3 Vengeance Jet Black, PC3-12800 (1600), Non-ECC, CAS 9-9-9-24, XMP, 1.50V
256GB Crucial RealSSD M4, 2.5" SATA 6Gb/s SSD, MLC-Flash, 500MB/s, Write 260MB/s *New Version*
1280MB Point of View GTX 570 Charged, 40nm, 3888MHz GDDR5, GPU 772MHz, Shader 1544MHz, 480 Cores
LG 10x Blu-ray Writer, 16x DVD±R, 8x +RW, 6x -RW, 12x RAM - Retail + Software
Coolermaster HAF X NVIDIA edition
Thanks
Caporegime
5 Sep 2010
Processor - Ivy Bridge should be out in a couple of weeks.
PSU - 850W is overkill unless you want it for future upgrades
Motherboard - Get a Z77 as they can be had for similar money to Z68
GPU - HD 7850 and clock the nuts off it
Case - You won't want an "Nvidia Edition" if you get an AMD GPU
RAM - You could buy a bit cheaper but whatever
Caporegime
5 Sep 2010
I am not sure on buying AMD I always saw that they were cheaper but why do you pay the extra money for Nvidia?
I don't think you need to worry about the whys just look at the performance.
There's no guarantee with overclocking but look at how far you can potentially overclock the HD 7850:
How to overclock a 7850 past 1050MHz?
If I was spending ~£200 on a new GPU today it's what I'd buy.
