Which case?
16 Aug 2010
UK
I'm looking to buy a new case that's quiet and looks 'sleek'. My current case is old, chunky (and a bit on the big side) and inadequate for cooling needs (i5 at 4.6ghz on air). Sure I could add some fans, sort the wiring out but meh I'd like a new case :p.
Some possibilities are:-
Fractal Design Define R3 Midi Tower Case
http://www.overclockers.co.uk/showproduct.php?prodid=CA-008-FD&groupid=701&catid=7&subcat=1556
People seem to rate that one highly.
Corsair Obsidian 550D Quiet Midi Tower Case
http://www.overclockers.co.uk/showproduct.php?prodid=CA-064-CS&groupid=701&catid=7&subcat=1489
Maybe the NZXT H2 Classic Silent Midi Tower Case
http://www.overclockers.co.uk/showproduct.php?prodid=CA-036-NX&groupid=701&catid=7&subcat=35
How do these cases compare? Any other suitable recommendations? Thank you :)
What about the fans that come with it? Is it worth swapping them for quieter (and possibly better!) fans?
And why not the H2?
Your corsair case looks nice although it's a bit big!
And why not the H2?
My case is the 600T white case not the biggest but it is fairly big.
the fans are ok as far as i no. but u can always cant them
the H2 has got a lot of bad reveiws.
H2 against R3 -
550D -
Yeah, R3 or 550D. Or maybe an Antec P280. All are solid cases, just depends on which you prefer (some have more drive bays, others more optical)... At this point it comes down to the smaller things, e.g. maybe niggles in appearance.
kd
