This is CPU bottleneck.
CPU wont show 100% because the CPU uses hyperthreading and BF3 doesn't like hyperthreading.
Using 470s in SLI I get approx 60 - 80fps with all setting maxed at 2560x1440
I've said it before in other threads & it seems it needs to be said again.
470s in SLI are bottlenecked even with the 920 clocked at 4Ghz, so of course 680s are going to be. What a waste of money buying 2 680s when your running a CPU that can only just handle 2 470/480s. You could turn SLI off and only use 1card you'd probably have the same FPS. This is not driver related, it is simply that the 920 is a huge bottleneck for more then 1 680. Especially in games that don't go well with Hyperthreading.
