I got these 2 boards and I have a few thoughts.
Firstly, the Asus I got with an I3, and while the I3 is back in there, I was using an I7 and while I was using the I7, I had an issue where i would simply hang when it was under some load... I never did resolve it.
However, with the I3, its rock steady stable.
Now, I got the Gigabyte P55-USB3 to replace the Asus, and it has done, however, I have an issue with the Gigabyte in that I cannot get it to recognise that I have more than 4GB
The annoying thing, is that in the BIOS, it shows me quite clearely that there is 2GB in each of the 4 slots ( 8GB in all ) and yet it says enabled on only 2 slots and a Dash on the ones that are not enabled and then it says that there is 4GB useable.
Windows ( Win 7 - 64Bit ) also says 8GB 3.99 useable and CPUZ shops me all the info for all 4 sticks.
So, what the heck is going on?
I am on BIOS F10i at the moment, I was on F7 when I got the board and it was doing the same thing, but I did notice that under F7, I had slots 1 and 3 enabled and now since F9, its been slots 1 and 2 enabled, so why the switch from slot 3 to slot 2?
Its alos not RAM compatibility a I have tried a number opf various types and they all do the same thing.
If Itry using one stick by the way, in one of the disabled slots, its bleeps like hell at me... In an enabled slot then its fine.
Any clues?
The thing is, that even with it only letting me use 4GB, it has been rock solid.
Now, as one thought, I did think that maybe there is a problem with the CPU and not the board? Could that be at all possible?
Well, the I7 came in another board, a really poor and very basic ACER M5811 and that worked with all the RAM and never crashed, so I did try the CPU back in there for a couple of days last week and it was perfcetly fine in it even running fully loadedon all 4+4 cores, so I think the CPU is just fine.
Im truly at a loss?
But another question Id love to know... Apart from the physical differences... What is the better board?
Gigabyte P55-USB3
Or
Asus P7H55-M
Any clues?
Im truly at a loss?
Gigabyte P55-USB3
Or
Asus P7H55-M
