Trip Computer: Fuel consumption accuracy by manufacturer/car
Man of Honour
Man of Honour
23 Dec 2002
London
Just curious about the accuracy of fuel consumptioon trip computers for your cars.
Over the years, I'd had a few, with the following:
- Mid 80s VW over-estimated by approx 50%
- Volvo S60 D5, over-estimated by approx 10%
- BMW E46 330i over-estimated by approx 5%
- BMW E91 330i pretty much bang on
So how do you find the accuracy of your cars?
Both Fords I've had show pretty close to the real amount used but as they only show average mpg over the last x miles and not the mpg between fill ups, it's difficult to compare accurately.
My 2008 A6 under-reads, maybe within 10%, I've not done a manual calculation for a while.
My E46 330d was pretty much spot on.
Fuel computer readings vs brimming tank/miles per tank calculation.
2002 Xsara VTS was consistently ~4mpg over per tank
2002 Renault Clio is consistently ~3mpg over per tank.
Toyota Yaris is almost spot on, it's about 2% ish higher than what it really is. Shows 40mpg when I worked out as 38.5 mpg etc.
Current car doesn't have a trip, but my Leon fr diesel did and it over estimated by around 20%. Also couldn't trust the fuel range either. Full tank said 600 miles when in reality you would get 450.
Mines is within 1 or 2% but I was able to manually correct it.
Worst culprits i've had for over reading were my A3 and various focus diesels - reading up to 20% over (the audi was the worst culprit)
My Ford Focus over reads by ~10%. The Monaro well I haven't work it out manually just incase it's actually worse than the computer says. :p
The only electrical luxury my car has is a 12hour clock, so I have to do mine manually :D
Pfft. I don't even have a fuel gauge. I have to take the cap off the tank (which doesn't lock, for the record) and shake the car to see how much is left in there :D
Her 207 gets nothing near the book figure so I have no reason to doubt the trip computer is reading high or low and it won't make much difference.
