My old setup was 2x Samsung P2350 monitors connected via DVI cables to my Sapphire 5850 with my large TV in the other room using the HDMI port for movies, etc.
About to upgrade to the HIS 7950 Fan 3GB GDDR5 PCI-E DVI/HDMI/2xMini DP and found that whole range only has one DVI & HDMI but now with display ports.
My question is if I keep my TV on the HDMI cable could I use the single DVI + Display port cable (if one around) for my two monitors?
Thank you
Thank you
