- 22 Mar 2009
- Cornwall
ok, not used this before, looks pretty straight forward. basically my thinking is, set this up on my server and share my media files and my data folder. then i can access this from my laptop at work or when im out and about, and on my dads pc.
now some of you might know i have tried WHS 2011 and like it, but am disapointed that you cant have different libraries for different users. so i was looking into this and found XBMC and Hamachi would allow me to get around this (i hope).
so my question(s) :
can i have more than 1 Hamachi network on my server? so that my dad (and any other user) can log into a different network and only see specific shared folders (therefore allowing individual libraries) failing that they can just map their folders, and then set XBMC to only use those.
also, my router (or BT not sure which) has a habit of changing WAN IP address, will Hamachi recognise this and change it accordingly or will i have to do what i do now and use TightVNC to login to the server and change it manually?
so my question(s) :
its surely no more open than WHS 2011 is using remote web connection, only with Hamachi i can see whats logged on and it needs to be approved before it can get access. plus if i connect my max 5 devices to it, then they wouldnt be able to add themselves to the network anyway.
