1066MHz RAM in a 800MHz capacity mobo?
12 Dec 2005
I only just noticed this, I have looked on my motherboard and it says DDRII 800 next to the RAM Slots but I have been running 2 X 2GB Corsair 1066MHz RAM for about a year and never really noticed any issues.
Would this cause a significant slowdown in my PC or something?
Cheers
The ram will run at the lower speed without issues.
Download CPU-Z and this will show your memory speed, you will need to double what cpu-z shows.
So is all this fine?
Cheers
Your running at 800mhz which is good, 1.8v is the standard voltage, if you get any issues you can / should able to increase the voltage in the BIOS.
Ah in the time I've had this RAM running I've never had those issues. :D
I was more worried that I'd maybe be getting a hit on performance. :)
