best ssd under £100.
13 Jan 2006
Wigan
so im half way through splitting my current pc into a gaming pc and a storage/streaming/general use pc.
heres the storage side that will be streaming to xbox 360s.
with the hdds from my current pc.
i now need a ssd to go with my current pc to become a gaming pc.
my goal is to play diablo 3(i play all my games on 360 but diablo is my favorite game series so im not missing it.)
my current spec will be:
q9400
4gb ram
i think a 5850
corsair 600w psu.
i think the cpu is with the standard cooler so would it be worth upgrading that and getting a small overclock to play diablo 3?
so i need a ssd to have windows 7 and diablo 3 on it and for under £100 and if its worth it a cpu cooler.
thanks.
the corsair looks good, is there any setup to do or is it just plug and play?
from the reviews its shipped with the latest firmware.
i will be limited to sata2 on my old mobo though.
SATAII is no problem it'll be very fast, you wont get the max speeds but you'll still get the fast boot/loading times which is what is actually noticeable.
Just install windows without any HDDs installed, and run WEI to make sure Windows picks up all the settings for the SSD and you're good to go :)
ordered, went with a sata 3 cable as it turned out cheaper than the sata 2 i picked :p and if i get a new mobo in the future one less thing to buy.
shall order my pc bits when i get paid next week, plenty time until diablo 3 comes out anyway :)
