**OcUK EXCLUSIVE - THE WORLDS FASTEST GTX 680 - KFA2 LTD OC!!
OcUK Staff
17 Oct 2002
OcUK HQ
Hi there
For those of you who have been drooling over the amazing Galaxy Hall Of Fame GTX 680 will also know Galaxy don't sell product in Europe. KFA2 is their European arm of the business.
So after some indepth discussions with my partner KFA2 and Galaxy we have the Hall of Fame card coming to the UK in a KFA2 box branded as a LTD OC Edition which is exclusive to OcUK. Key points to this card are:-
  • 2x 8pin Connectors, so upto 300W TDP
  • 3x 90mm Fan Cooling design, powerful yet quiet
  • Custom GX31 controller chip for software voltage control
  • WHITE PCB DESIGN
  • 8+2+2 Power Phase Design
KFA2 GeForce GTX 680 LTD OC 2048MB GDDR5 PCI-Express Graphics Card @ £529.99 inc VAT
The Galaxy GTX 680 Hall of Fame edition is based on a white PCB with two 8 pin PCI-E power connectors for a maximum TDP of 300W for immense overclocking. Further, it is cooled with three 90mm fans and five heatpipes leading to an aluminum fin array. The card will come equipped with dual BIOS support and overclocking software. With higher power TDP, better cooling and far superior power phase along with a custom GX31 processor for software voltage control this will be one if not the best clocking GTX 680 on the market.
The GeForce® GTX 680 delivers more than just state-of-the-art features and technology. It gives you truly game-changing performance that taps into the powerful next-generation GeForce architecture to redefine smooth, seamless, lifelike gaming.
Immerse yourself in an ultra-smooth gaming experience with exciting new NVIDIA technology advancements like NVIDIA Adaptive Vertical Sync. It’s a fast, seamless way to adjust VSync to your current frame rates for maximum playability.
Features:-
- Innovative new GeForce architecture, designed to deliver faster, more power-efficient performance
- NVIDIA GPU Boost technology that dynamically maximizes clock speeds to push performance to new levels and bring out the best in every game
- The power to turn on lightning-fast anti-aliasing in a huge variety of games, automatically, with NVIDIA FXAA
- The power of 3-way NVIDIA SLI® technology
- Ultra-smooth gaming experience with exciting new NVIDIA technology advancements
- NVIDIA Adaptive Vertical Sync adjusts VSync to current frame rates for maximum playability
- NVIDIA 3D Vision® Surround multi-monitor gaming on a single GPU (three gaming monitors plus one accessory display) - for the first time ever
- Supercharged NVIDIA PhysX® and NVIDIA 3D Vision® performance
- New 28nm process means cooler, quieter and far superior overclocking potential than previous generation graphics cards
Specification:-
- KFA2 Own White-PCB Design GeForce GTX 680
- Innovation Cooler Design giving powerful yet silent cooling with 3x 90mm fans
- Extreme Overclocking Performance
- 8-Phase Core PWM (8+2+2)
- 2+2-PhaseMemory PWM
- Galaxy custom GX31 chip with software voltage control, voltage monitoring and power draw monitoring
- Core Clock: 1202MHz (GK104)
- Core Boost Clock: 1267MHz
- Memory: 2048MB GDDR5
- Memory Clock: 6008MHz (Effective)
- Memory Interface: 256-Bit
- Processing Cores: 1536
- Shader Clock: 2404MHz
- Bus Type: PCI-Express GEN 3.0 (Backwards compatible)
- Display Connectors: 1x DisplayPort, 3x HDMI 1.4a (300Mhz Transmitter for 120Hz)
- SLI Ready (Upto 3-Way SLI Supported)
- HDCP Capable
- DirectX 11 Support
- OpenGL 4.0 Support
- PhysX Enabled
- CUDA Enabled
- 3D Vision Enabled
- NVIDIA Surround Enabled
- Lower power consumption (Maximum consumption 195 watts at stock speed)
- 1x 8-Pin + 1x 6-Pin PCI-E Connectors required
- Card Dimensions: 270*111.15*38.75 mm
- Warranty: 2 Years
Only £529.99 inc VAT.
ORDER NOW
This card is superb for those looking to setup a multi-display setup that won't cost an epic fortune:-
KFA2 GeForce 210 MDT "SILENT" 1024MB DDR2 Multi-Display PCI-Express Graphics Card @ £79.99 inc VAT
The only GeForce graphics card on the market that supports quad 1080p displays. Ideal for heavy multi-tasking business and home users.
Features:-
- New 1080p driver release update driver
- 1 card = 4 displays
- Powered by IDT ViewXpand VMM1402
- 2x2 display stacking
- Comes with x2 DMS59 cables
- Each cable supports two single link DVI
- Only supports DVI displays (VGA Converters are not compatible)
- Cores: 16
- Graphics Clock(MHz): 589
- Processor Clock(MHz): 1402
- Memory Clock(MHz): 400 (effective 800)
- Memory Amount: 1GB
- Memory Interface: 64-bit DDR2
- Memory Bandwidth(GB/Sec): 6.4
- 2yr Warranty
Only £79.99 inc VAT.
ORDER NOW
Hi there
We shall certainly post a review of this product up, once we get our first test sample or first shipment of stock. :)
beautiful card, nice specs....although the PP is too much £499.99 would've been better.
Maaaann if only i had a 10% discount code...
BUT PLEASE WE NEED A REVIEW BENCHMARKS GOO
I'm not convinced - £500+ for a 2gb model seems just too pricey. That's about £100 premium for very little tangible gain over the LAUNCH priced GTX 680.
