Also, before "google benchmarks", I actually have, but there seems to be a lot of discrepancy over which is better, in terms of temperatures varying between brands, power-draw and performance between different games, as-well as the age-old ATI vs Nvidia..
AFAIK OcUK don't _usually_ sell reflows tho there may be the odd one that comes back from the manufacturer.
A 6970 crapping out its guts through its mouth (IE around 1ghz) is about level with a stock 580. That was about the best I managed to do with the 6970 Lightning I had, which was pretty much dead even with the results Vortez got in the review of the Radeon.
So the 6970 is a card that should be compared with the fair comparison, and that is the 570 which it manages to beat ever so slightly. But it doesn't even stand in the same room as a 580. Well, not if you overclock both cards.
What would concern me is why they are B stock. If they are simple returns then fair enough. However, if they have been baked in a reflow oven I would be suspicious of their longevity.
Should the B-Grade 7970 be lower priced than a new one????
