multiplyer 6 x should be 9 x ?
You also need to set the Windows power plan to High Performance.
Why do you want it to run at x9 all the time? It will clock back up to normal when needed and drop to x6 when idle, thus lowering temps and saving power, which will help the CPU last longer.
because i wanted a small boost
yes your probably right there,
i think i mentioned it been a while since overclocking.
another reason for doing it this way is because havnt had much time to go on pc recently so it easyer to check how stable i am running at full load from starting pc than running prime 95 overnight if you get what i mean.
Sadly it doesn't work that way. Even if it starts up at full speed, there still won't be significant load to fully test the overclock. Prime/Intel burn test is the only way to fully test for stability...
intel burn test it was ok / just dont have time to run prime 95 for few hours
Yooooooou cowboy lol
The guys are 100% right. Leave the speed step enabled to give your CPU a "breather" when it's not needed to run flat out. There is a similar feature for GPUs as well.
HD video playback doesnt even fully utilise all of my HTPCs 2 cores. Do the stress testing or any batch video encoding over night....the electric is cheaper and whilst you sleep you won't miss the use of the rig.
ok so im being lazy ....lol , ill set thing back near normal but overclocked to 3.1ghz at full load, ill run prime95 over night and see how i get on
I would stick with the known and trusted Gelid or perhaps a silver arrow.
How much time do you spend looking at the cooler, :-)
