oh and another thing can someone please point out - show a pic or photo of where the coil is located on their GPU.
..... this may help you understand whats going on..http://en.wikipedia.org/wiki/Coil_noise
What is happening more and more with the current gen of Vid Cards is that they are causing the coils within PSUs to resonate closer to the human audible range. Its always been there. Some PSUs do a better job of dampening it others don't. The fact that u can get lucky with replacing the GFX card is only disguising the problem that lies within the PSU. Not every Vid card will draw the exact same power therefore it can appear that changing the video card works. It doesn't the fact is that all that happened was you put a card in that lowered that frequency below ur range. It has nothing to do with the wattage of the PSU rather how the PSU coil has been designed and dampened.
For those interested, the application of a dab of glue onto the coil fixes the problem as it changes the resonating properties of the coil. You will see more and more PSUs come out with figure of eight coils as this helps immensely. Oh the application of glue will ofc void any warranty.
......... this may help you understand whats going on..http://en.wikipedia.org/wiki/Coil_noise
