Giga GTX680 'Windforce 5x'
HeX
HeX
20 Jun 2004
Huddersfield, UK
http://www.techpowerup.com/164528/G...ion-on-GTX-680-SOC-Pictured-5-Fan-Mayhem.html
Just why? :confused: 5x 40mm fans... are they mad?!?!
so it ventilates in one direction only, but i couldn't be bothered to read any more..
basically it's total and utter Krap, it's like that massive Chinese GTX 680, Alien on board a mining vessel, with Auto Destruct set to ``T minus 5 mins and counting`` :D:D
these Chinese are idiots, they're so far off the mark, it looks totally uncool.
Looks terrible and using so many small fans is likely to be less reliable. It looks like it was designed by an amateur modder.
I would want to smash that thing's head in with a hammer.
My Alienware used to (note, past tense) have two fans that size in it. One was on the Northbridge and the other over the memory. Both of them were taken out.
They make the most horrid, putrid and annoying whirring sound EVER.
What a bunch of bumhats.
That looks just wrong, and I bet the really noisy. Why do they think adding more fans is a good idea?
If you want do something different, then add standalone phase cooling mod ;)
