- 30 Sep 2005
Hi all,
I'm planning on buying another two of the 27" catleap monitors to go with 2 x 7850 Crossfire cards.
am I right in thinking the following:
Monitor 1 - DVI-D from Graphics Card A
Monitor 2 - DVI-D from Graphics Card B
Monitor 3 - Mini DP > DVI-D from Graphics Card A or B
I know DP 1.2 specs are compliant with 2560x1440 but I can only find DP 1.1 cables on the market. Do I need a cable, or will I need some kind of expensive adapter (which seem to be also 1.1 compliant only)
Thanks!!
Thanks!!
