I get what speedfreak is trying to say, he's assuming that at least one of the people in that 35k a year group is living their 30,000th day.
There were 35000 runners and the average person lives for around 30,000 days therefore on average one runner of the marathon will die on the day they run it (assuming an average demographic)
Not sure why people are having issues with is. SpeedFreak is right, get 35,000 people together for a day and statistically speaking one is likely to die. The important thing is, as SpeedFreak pointed out, is the demographic. Clearly the marathon runners are not an average demographic - not many over 70, but also none under 16. Very few people die under 16 so that make the marathon cohort more likely to produce a death, however, the under representation at old age makes it less likely to produce a death. With the proviso though, SpeedFreak is right.
UK Population 62,200,000
UK Deaths per day 2,000
Therefore blanket chance of death per day ignoring circumstances is:
1 : 31,100
Which isn't too far from your statistic, however, once you factor in the majority of deaths are related to old age and most of the runners are in peak physical fitness and relatively young then the chances are lowered. Based on historical stats form the marathon there is a 1 in 3 chance of a runner dying any year. Which based on the number of runs says that there is 1 : 100,000 chance of a runner dying. Which ties in with the above stat once circumstance is applied.
What you said still isn't right. Saying people on average live for 30,000 days isn't the same as stating that one in 30,000 die each day.
I get it too, but that's not how statistics work.
It's like saying "If you flip a coin 10 times and it's heads every time, it's more likely that it'll be tails the 11th time".
No, that's not quite the same as saying that one person will die from a group of 30,000. SpeedFreak is not assuming that the distribution is uniform, but that is is the average.By saying life expectancy is roughly 30,000, you then assume that it is equally likely that a person will die on any one of these days.
I would post my educational credentials as well but if I'm wrong it will be embaressing![]()
