Spec me.......a PSU!!
23 May 2009
Hants/Berks Border
I would suggest getting an Antect truepower 650w just from personal expirience as it is hybrid modular 80plus bronze with a nice cable management sleeve system or you could get a G7 as i owned one and they are NOT a cheap brand but they are not expensive either Corsairs are alright as their PSU's are made by diffirent companies so im not sure what you would be getting with that one but from research seasonic made the antec which is a good make
Isn't that G7 psu the one that blew up :confused:
a lot of power supplies blow up yes even the corsair ones however if you are on a budget like i was at one point G7 served me very well and the reason i upgraded is because i needed more 6pins and an 8 pin for cpu as i only has 1 6pin and 2 4 pins
I think its just best to go with a good brand, because even when things go wrong they have good protection and mostly good warranty services.
Also, your sig is too big [4 lines max] you might want to change it before a mod sees!
