- 29 Feb 2012
Apart from 55 pounds price? ta
The XL2410T had some annoying issues such as inverse ghosting (overdrive trailing) and backlight bleeding.
The XL2420T was the new model that effectively fixed these issues and also supported "lightboost" for Nvidia 3D vision2.
Therefore, if you are going for a 120Hz monitor I would strongly recommend you spend the extra on the XL2420T.
Excellent monitor, never looked back and considering a 2nd.
