Hi guys, Can somone spec me a killa gaming pc witha budget of £1000
3 Feb 2011
Southend On Sea, Essex
I had a basic outline of what I wanted but didn't know if it would work, so I thought id ask you guys for some Specs
There was a post on here a second ago with two specs on it, now its gone :/ was interested in them lol
That was me, sorry I made a mistake! The spec above now includes all you'd need. Case is more of a personal choice though, so if you find one you prefer we can check it would fit if you like?
Also, is your OS 64bit?
I didnt really catch the name of the white case you linked but it did look fresh. Yh I have Windows 7 ultimate 64bit
YOUR BASKET
1 x VTX3D HD 7850 2048MB GDDR5 PCI-Express Graphics Card with FREE Dirt3 PC Game £174.98
1 x Intel Core i5-2500K 3.30GHz (Sandybridge) Socket LGA1155 Processor - Retail £173.99
1 x Asrock Z77 Extreme6 Intel Z77 (Socket 1155) DDR3 Motherboard £169.99
1 x Crucial RealSSD M4 128GB 2.5" SATA 6Gb/s Solid State Hard Drive (CT128M4SSD2) £116.99
1 x XFX 850W XXX Edition Modular '80 Plus Silver' Power Supply £99.98
1 x Seagate Barracuda Green 2TB SATA 6Gb/s Hard Drive - OEM (ST2000DL003) £89.99
1 x Zalman Z9 Plus Tower Case with Fan Controller - Black £52.99
1 x Corsair Vengeance Low Profile 8GB (2x4GB) DDR3 PC3-12800C9 1600MHz Dual Channel Kit (CML8GX3M2A1600C9) £39.95
1 x Gelid Tranquillo CPU Cooler (Socket 754/939/940/AM2/AM2+/AM3/LGA775/LGA1155/LGA1156/LGA1366) £23.99
1 x LG GH22NS70 24x DVD±RW SATA ReWriter (Black) - OEM £18.98
Total : £976.84 (includes shipping : £12.50).
I would wait till the end of the month for the intel ivybridge CPUs though. Gives you an idea for your budget though :)
That case has 4 fans, digital temp display with fan controller and cable management. The high end mobo has a break out box which will give you USB3 ports in the 3.5 inch bay.
I definatly would like:
Titan fenrir
Corsair Carbide 500R
Asrock Z77 FATAL1TY Professional-M
Can you see whats possible?
Cheers guys thanks for what youve come up with so far :D
Yes probably, but you might have to cut back elsewhere. Any reason? Only the Gigabyte in my spec supports crossfire/SLI. That's not a bad board, just not sure its worth the extra really.
TBH, I got recommended it and it does look pretty cool
