24 Apr 2012 at 14:23 #1 utajoker utajoker Soldato Joined 13 Jan 2006 Posts 21,115 Location Wigan i was all set to buy this build: but just before i did a friend said i should look at amd for low end. so i came up with this: useage is: storage downloading web use which is the better choice?
24 Apr 2012 at 14:39 #2 stulid stulid Caporegime Joined 17 Jan 2010 Posts 66,731 Location weston-super-mare The top one but with this board - http://www.overclockers.co.uk/showproduct.php?prodid=MB-386-GI&groupid=701&catid=5&subcat=1965
24 Apr 2012 at 14:55 #3 utajoker utajoker Soldato OP Joined 13 Jan 2006 Posts 21,115 Location Wigan what makes that board better?
24 Apr 2012 at 15:17 #4 stulid stulid Caporegime Joined 17 Jan 2010 Posts 66,731 Location weston-super-mare utajoker said: what makes that board better? Click to expand... USB3.0 at the rear and two SATAIII ports.
24 Apr 2012 at 17:36 #5 Jak3 Mac Jak3 Mac Associate Joined 14 Apr 2012 Posts 213 Location Liverpool, England stulid said: The top one but with this board - http://www.overclockers.co.uk/showproduct.php?prodid=MB-386-GI&groupid=701&catid=5&subcat=1965 Click to expand... I would go for that
24 Apr 2012 at 19:05 #6 utajoker utajoker Soldato OP Joined 13 Jan 2006 Posts 21,115 Location Wigan Neither are that important for the build but I do like the 6 sata ports. It's also micro atx so I can have the case from the 2nd spec. Thx
24 Apr 2012 at 19:11 #7 stulid stulid Caporegime Joined 17 Jan 2010 Posts 66,731 Location weston-super-mare That Lian-Li says its Mini-ITX only, so it wont fit.
25 Apr 2012 at 07:28 #8 utajoker utajoker Soldato OP Joined 13 Jan 2006 Posts 21,115 Location Wigan Ah misread the mobo Shall have to see when this one will be back in stock. http://www.overclockers.co.uk/showproduct.php?prodid=CA-016-FD&groupid=701&catid=7&subcat=2278
26 Apr 2012 at 17:19 #9 utajoker utajoker Soldato OP Joined 13 Jan 2006 Posts 21,115 Location Wigan stuff arrived
