This was discussed before:
http://forums.overclockers.co.uk/showthread.php?t=18370389
Hope that helps.
I don't think you'll see full 100mb on the WRT54GL even with Tomato/DD-WRT installed on it. Seem to remember reading it starts to get flakey around the 30-50meg mark.
I'd probably take this opportunity to upgrade to something a bit quicker, Asus RT-N16/RT-N56, Linksys WRT300N or similar to stick with the open source linux based routers
Edit: thats the link above I read about it being flakey![]()
+1 for the Asus RT-N16.
Brilliant router, installed TomatoUSB on it and couldn't be happier.
These open source Linux based routers really are excellent.
Same, I bought one to upgrade from a WRT54GL and it's been solid. TomatoUSB also installed with VPN setup on it too.
The thing I like the most is that its pretty hard to brick....I managed to flash it with the wrong firmware after messing about with the TomatoUSB I had installed and "bricked" the router. All I can say is thank god for its hardware recovery mode, I just booted it up in that and flashed with the right firmware, no problems
The only thing I think it's missing is dual band wireless, but I think the RT-N56 has that doesnt it?
