Trials Evolution
I can only dream of gold on every track :o
I need to practice a lot on this.
I struggled like hell getting up the final ramp on Trible Trouble, I always ended up falling backwards.
If you didn't play the harder original game you will find it difficult. Stay with it, there is a technique for every obstacle that needs to be learned. Try not to stress out and watch some replays to see how other people have done it. Eventually it will all fall into place :)
Do you think it would be worth buying Trials HD?
I love Evolution and think it's a brilliant game, so would be very open to buying HD as well if it will help with Evolution.
All hard tracks and the first extreme have 0 faults with gold on all. 2nd extreme looks pretty easy as well so hope to get that sorted on my next go. Really is an awesome game :)
first two extremes arent too bad. i managed to get platinum with a lot less swearing than expected. however things get much harder after that so i went to platinuming the first tracks. all of the beginner ones are now dealt with and i've just started on the easy tracks :)
Anyone managed to get the achievement for doing "the ascent" on the rattle without faulting? I can do the whole track perfect apart from one simple jump and its driving me crazy!
I've done it. Took me a while to workout the best way over each obstacle and then stringing them all together perfectly, but I managed it, its far from impossible.
i think i have. which bit are you having problems with?
It's pretty much the second jump, two pieces of pipe with a gap inbetween, and a single exploding box in the middle, I just don't seem to be able to quite get the distance, keep catching the back tire on the lip and flipping back. Rest of the track is fine :0
Can anyone shed any light on this issue.
Im trying to play the game in local multiplayer with my GF so we can can compete against each other and yet we can only select from 12 tracks. Mostly Beginner and Easy tracks and one Medium. Why can't we select any other tracks. It sucks because we are already bored of these same tracks and want to play others too. We both have the licences and have played through all the tracks to the extreme tracks so we both are at the same level in the single player game.
Can anyone help ?
you can only play supercross tracks in local multiplayer. however, i think you can download other supercross tracks made by the community and play those in multiplayer
Ah right that makes sense now youve said that :) thanks. Bit rubbish but thanks
as far as i know its just that the xbox cant handle the computation of running the graphics engine 4 times, as would be necessary for splitscreen multiplayer.
*mutters to himself about consoles holding back games*
basically you want to take as mch speed as possible through the entire previous section, while leaning forwards the entire time until your just about to land, then go neutral for a bit so you dont hit your front wheel. hopefully this video helps:
This is definitely easier than Trials HD imo. I do think it's better though.
Got gold or platinum on every track except the Extreme ones, waiting for my mates to set some times on the later tracks so we can get some competition going, no fun just playing against yourself!
Until then, it's rage time for me, I can already tell I'll never finish Inferno 3.
