- 11 Dec 2005
- Cheshire
For our 4th round of epic weekend deals we have some fantastic pricing on motherboards and our fantastic "Krypt PRO" Quad core AMD gaming system
Z77 Ahoy! Don't worry we have some AMD in here too
Asus P8Z77-V LX Intel Z77 (Socket 1155) DDR3 Motherboard @ £84.98 inc VAT
The P8Z77-V LX with a 32GB DDR3 memory and PCLe 3.0, features the new Intel Z77 express chipset and supports a 22/32 nm CPU providing excellent overclocking capabilities of up to 2400 MHz. It also caters to a wide range of end users by including features such as AMD Crossfire for the ultimate multi-GPU performance gaming platform and Network iControl to perfectly manage bandwidth.
The P8Z77-V LX also includes Dual Intelligent Processors 3 and Smart Digi+ VRM consisting of two onboard chips, the TPU and EPU. This also consists of multiple digital voltage controllers that allow for ultra-precise tuning of CPU and iGPU, including an 85% CPU frequency boost, while working with the TPU to ramp up performance to full potential for the ultimate user experience. Another incredible feature is Fan Xpert which enables the most customizable fan controls ever offered on a motherboard. While another ASUS exclusive feature includes the UEFI BIOS with a multi-language setting offering a mouse controlled and user friendly interface.
Containing 4 USB 3.0 ports with USB boost UASP which gains unprecedented speed, the P8Z77-V LX also features LudicLogix Virtu MVP which boots responsiveness, improves gaming frame rates by 30-70%, sharpens visual quality and works seamlessly with hundreds of game stations. Thus making The P8Z77-V LX a multifaceted motherboard for excellent quality and value!
Asus Exclusive Innovations:
· SMART DIGI+ Power Control
· Fan Xpert+
· Network iControl
· USB 3.0 Boost
· AI Suite II
Innovations:
· Dual Intelligent Processors 3 - with New DIGI+ Power Control include three digital voltage controllers, allowing ultra-precise CPU voltage control
· Quad GPU AMD CrossfireX - a flawless architecture accommodating the power of up to four graphics cards
· LudicLogix Virtu MVP - boots responsiveness, improves gaming frame rates by 30-70% and sharpens visual quality
Spec details:
Model
P8Z77-V LX
Chipset
Z77
Power Phase
DIGI+ VRM 4+1 Phase
Graphics
1*PCIe 3.0 x16 slot
1*PCIe 2.0x16
VGA
HDMI/DVI/RGB
LucidLogix Virtu MVP
YES
SLI/CrossFire
CrossFireX
PCI
3
PCIex1
2
Storage
2*SATA 6Gb/s
4*SATA 3Gb/s
LAN
1*Realtek Gb LAN
1394
N/A
USB
4*USB 3.0
10*USB 2.0
Wi-Fi Support
N/A
Audio
ALC887
Accessories
2*SATA 6G cable
ASUS Unique Features
DIGI+VRM
Network iControl
Fan Xpert+
USB 3.0 Boost
AI Suite II
BIOS
UEFI BIOS
Form Factor
ATX
Was £99.99 Inc. VAT
Only £84.98 inc VAT.
ORDER NOW
Asrock Z77 FATAL1TY Professional Intel Z77 (Socket 1155) DDR3 Motherboard @ £174.98 inc VAT
ASRock motherboard support Lucid Virtu Universal MVP technology that improves your PC’s visuals, with faster response times, improved video processing and smoother media playback, all with low power consumption. Brilliantly designed for gaming, Virtu Universal MVP™ switchable graphics software assigns tasks dynamically to the best graphics resource and features two exciting techniques – HyperFormance™ and Virtual Vsync™.
CPU
- Supports 3rd and 2nd Generation Intel® Core™ i7 / i5 / i3 in LGA1155 Package
- Digi Power Design
- 16 + 8 Power Phase Design
- Supports Intel® Turbo Boost 2.0 Technology
- Supports Intel® K-Series unlocked CPU
- Supports Hyper-Threading Technology
Chipset
- Intel® Z77
- Supports Intel® Rapid Start Technology and Smart Connect Technology
*Intel® Rapid Start Technology and Smart Connect Technology are only supported under Windows® 7 OS or later versions.
Memory
- Dual Channel DDR3 memory technology
- 4 x DDR3 DIMM slots
- Supports DDR3 2800+(OC)/2400(OC)/2133(OC)/1866(OC)/1600/1333/1066 non-ECC, un-buffered memory
- Max. capacity of system memory: 32GB*
- Supports Intel® Extreme Memory Profile (XMP) 1.3 / 1.2
*Due to the operating system limitation, the actual memory size may be less than 4GB for the reservation for system usage under Windows® 32-bit OS. For Windows® 64-bit OS with 64-bit CPU, there is no such limitation.
BIOS
- 64Mb AMI UEFI Legal BIOS with GUI support
- Supports "Plug and Play"
- ACPI 1.1 Compliance Wake Up Events
- Supports jumperfree
- SMBIOS 2.3.1 Support
- CPU Core, IGPU, DRAM, 1.8V PLL, VTT, VCCSA Voltage Multi-adjustment
Audio, Video and Networking
Graphics
- Supports Intel® HD Graphics Built-in Visuals : Intel® Quick Sync Video 2.0, Intel® InTru™ 3D, Intel® Clear Video HD Technology, Intel® Insider™, Intel® HD Graphics 2500/4000
- Pixel Shader 5.0, DirectX 11 with Intel® 22nm CPU. Pixel Shader 4.1, DirectX 10.1 with Intel® Sandy Bridge CPU.
- Max. shared memory 1760MB
- Dual VGA Output: support HDMI and DisplayPort ports by independent display controllers
- Supports HDMI 1.4a Technology with max. resolution up to 1920x1200 @ 60Hz
- Supports DisplayPort with max. resolution up to 2560x1600 @ 60Hz
- Supports Auto Lip Sync, Deep Color (12bpc), xvYCC and HBR (High Bit Rate Audio) with HDMI (Compliant HDMI monitor is required)
- Supports HDCP function with HDMI and DisplayPort ports
- Supports Full HD 1080p Blu-ray (BD) / HD-DVD playback with HDMI and DisplayPort ports
*Intel® HD Graphics Built-in Visuals and the VGA outputs can be supported only with processors which are GPU integrated.
**Due to chipset limitation, the Blu-ray playback of Intel® HD Graphics is only supported under Windows® Vista™ and Windows® 7.
***Intel® InTru™ 3D is only supported under Windows® 7 and Windows® 7 x64.
Audio
- 7.1 CH HD Audio with Content Protection (Realtek ALC898 Audio Codec)
- Premium Blu-ray audio support
- Supports THX TruStudio™
LAN
- PCIE x1 Gigabit LAN 10/100/1000 Mb/s
- Broadcom BCM57781
- Supports Wake-On-LAN
- Supports Energy Efficient Ethernet 802.3az
- Supports Dual LAN with Teaming function
- Supports PXE
Expansion / Connectivity
Slots - 2 x PCI Express 3.0 x16 slots (PCIE2/PCIE4: single at x16 (PCIE2) / x8 (PCIE4) or dual at x8/x8 mode)
- 1 x PCI Express 2.0 x16 slot (PCIE5: x4 mode)
- 2 x PCI Express 2.0 x1 slots
- 2 x PCI slots
- Supports AMD Quad CrossFireX™ , 3-Way CrossFireX™ and CrossFireX™
- Supports NVIDIA® Quad SLI™ and SLI™
*PCIe Gen3 is supported on 3rd Generation of Intel® Core™ i5 and Core™ i7 CPUs.
SATA3
- 2 x SATA3 6.0 Gb/s connectors by Intel® Z77, support RAID (RAID 0, RAID 1, RAID 5, RAID 10, Intel® Rapid Storage and Intel® Smart Response Technology), NCQ, AHCI and "Hot Plug" functions
- 4 x SATA3 6.0 Gb/s connectors by ASMedia ASM1061, support NCQ, AHCI and "Hot Plug" functions (SATA3_A4 connector is shared with eSATA3 port)
USB 3.0
- 2 x Rear USB 3.0 ports by Intel® Z77, support USB 1.0/2.0/3.0 up to 5Gb/s
- 4 x Rear USB 3.0 ports by Etron EJ188H, support USB 1.0/2.0/3.0 up to 5Gb/s
- 1 x Front USB 3.0 header by Intel® Z77 (supports 2 USB 3.0 ports), supports USB 1.0/2.0/3.0 up to 5Gb/s
Connector
- 4 x SATA2 3.0 Gb/s connectors, support RAID (RAID 0, RAID 1, RAID 5, RAID 10, Intel® Rapid Storage and Intel® Smart Response Technology), NCQ, AHCI and Hot Plug functions
- 6 x SATA3 6.0 Gb/s connectors
- 1 x ATA133 IDE connector (supports 2 x IDE devices)
- 1 x Floppy connector
- 1 x IR header
- 1 x COM port header
- 1 x HDMI_SPDIF header
- 1 x IEEE 1394 header
- 1 x Power LED header
- CPU/Chassis/Power FAN connector
- 24 pin ATX power connector
- 8 pin 12V power connector
- CD in header
- Front panel audio connector
- 2 x USB 2.0 headers (support 4 USB 2.0 ports)
- 1 x USB 3.0 header (supports 2 USB 3.0 ports)
- 1 x Dr. Debug with LED
Rear Panel I/O I/O Panel
- 1 x PS/2 Keyboard/Mouse Port
- 1 x HDMI Port
- 1 x DisplayPort
- 1 x Optical SPDIF Out Port
- 5 x Ready-to-Use USB 2.0 Ports
- 1 x Fatal1ty Mouse Port (USB 2.0)
- 1 x eSATA3 Connector
- 6 x Ready-to-Use USB 3.0 Ports
- 2 x RJ-45 LAN Ports with LED (ACT/LINK LED and SPEED LED)
- 1 x IEEE 1394 Port
- 1 x Clear CMOS Switch with LED
- HD Audio Jack: Rear Speaker / Central / Bass / Line in / Front Speaker / Microphone
Other Features / Miscellaneous
Unique Feature
- F-Stream
- ASRock Instant Boot
- ASRock Instant Flash
- ASRock APP Charger
- ASRock SmartView
- ASRock XFast USB
- ASRock XFast LAN
- ASRock XFast RAM
- ASRock Crashless BIOS
- ASRock OMG (Online Management Guard)
- ASRock Internet Flash
- Lucid Virtu Universal MVP
- Hybrid Booster:
- CPU Frequency Stepless Control
- ASRock U-COP
- Boot Failure Guard (B.F.G.)
- Combo Cooler Option (C.C.O.)
- Good Night LED
*Lucid Virtu Universal MVP can be supported only with processors which are GPU integrated.
**LucidLogix Virtu MVP is only supported under Windows® 7 OS or later versions.
Smart Switch
- 1 x Power Switch with LED
- 1 x Reset Switch with LED
Support CD
- Drivers, Utilities, AntiVirus Software (Trial Version), CyberLink MediaEspresso 6.5 Trial, ASRock MAGIX Multimedia Suite - OEM
Accessories
- 1 x ASRock SLI_Bridge_2S Card
- Quick Installation Guide, Support CD, I/O Shield
- 6 x SATA Data Cables
- 2 x SATA 1 to 1 Power Cables
- 1 x Front USB 3.0 Panel
- 4 x HDD Screws
- 6 x Chassis Screws
- 1 x Rear USB 3.0 Bracket
Hardware Monitor
- CPU Temperature Sensing
- Chassis Temperature Sensing
- CPU/Chassis/Power Fan Tachometer
- CPU/Chassis Quiet Fan (Allow Chassis Fan Speed Auto-Adjust by CPU Temperature)
- CPU/Chassis Fan Multi-Speed Control
- Voltage Monitoring: +12V, +5V, +3.3V, CPU Vcore
Form Factor
- ATX Form Factor: 12.0-in x 9.6-in, 30.5 cm x 24.4 cm
- Premium Gold Capacitor design (100% Japan-made high-quality Conductive Polymer Capacitors)
OS
- Microsoft® Windows® 7 / 7 64-bit / Vista™ / Vista™ 64-bit / XP / XP 64-bit compliant
Certifications
- FCC, CE, WHQL
- ErP/EuP Ready (ErP/EuP ready power supply is required)
Was £189.99 Inc. VAT
Only £174.98 inc VAT.
ORDER NOW
Asus P9X79 PRO Intel X79 (Socket 2011) DDR3 Motherboard @ £191.98 inc VAT
At the very top end of motherboard performance, the P9X79 series from ASUS brings you complete power, enhanced with unmatched flexibility and boundless tuning possibilities. These new boards launch with the world’s first digital power controls for both the CPU and memory, thanks to exclusive ASUS New DIGI+ Power Control Technology. They further put power right in your hand via UEFI BIOS, the most detailed and accessible BIOS ever, allowing you to tune your system to its full performance potential. While user-friendly from the ground-up, the P9X79 Series ships with the latest features, including exclusive ASUS SSD caching for one-click performance boosting through the benefits of solid state drive technology. You also get USB BIOS Flashback for the easiest ever BIOS modification – all it takes is a USB stick and one button press! Sign up for total power and performance insight with the new ASUS P9X79 Series.
The world’s first Dual Intelligent Processors from ASUS pioneered twin on board chips – TPU (TurboV Processing Unit) and EPU (Energy Processing Unit). Third generation Dual Intelligent Processors with New DIGI+ Power Control include two digital voltage regulator modules (VRMs). An all-new digital controller now allows ultra-precise DRAM tuning. EPU provides system energy saving and real time power management. TPU delivers a second micro-processor to free CPU resources as well as easy O.C. and an instant performance boost through an on-board switch or the easy O.C. tool, TurboV EVO.
ASUS Unique Selling Points:
ASUS Dual Intelligent Processors 3 with New DIGI+ Power Control:
CPU Power: Industry leading Digital 8+2 Phase Power Design and CPU Power Utility
DRAM Power: Industry leading Digital 2+2 Phase Power Design and DRAM Power Utility
ASUS EPU and EPU switch: Automatically provides the most appropriate power usage to save power and money.
ASUS TPU with Auto Tuning and TurboV with Switch: Providing simple steps to easy overclocking.
ASUS BT GO!: Bluetooth on-board for easy Folder Sync, BT Transfer, Shot & Send, BT to Net, Music Player, Personal Manager, BT Turbo Remote
ASUS EFI BIOS(EZ Mode):The most flexible and easy to use Bios.
ASUS SSD Caching: 3x Faster storage performance with one click
USB 3.0 Boost: Make USB 3.0 speeds faster than ever (UASP Mode)
Front Panel USB 3.0 Support: Support for cases with front USB 3.0
MemOK!: Quickly ensures memory boot compatibility with failsafe settings.
AI Suite II: One stop access to all Asus features.
Ai Charger: Faster USB charging speed.
Fanless Design: Silent Heat-sink solution
Fan Xpert+: Smart thermal control via fan speed detection.
ASUS Q-Code: Allows easy fault diagnosis
ASUS Q-Shield: Extra Secure I/O Shield
ASUS Q-Slot: Easy access expansion slots.
ASUS Q-DIMM: Easy access dimm slots.
ASUS Q-LED (CPU, DRAM, VGA, Boot Device LED):
ASUS Q-Connector: Easy access front panel connector
USB BIOS Flashback: Flash your Bios in 1 easy step, no CPU or RAM required.
ASUS O.C. Profile: Easily store multiple overclock profiles.
CrashFree BIOS 3: Restore corrupted BIOS data from a USB flash disk
EZ Flash 2: Easily update your systems bios firmware.
MyLogo 2: Update your own windows boot screen.
Percision Tweaker 2: Advanced overclocking tools.
Multi-language BIOS: easily change Bios to your language.
Asus Overclocking Features:
Precision Tweaker 2:
- vCore: Adjustable CPU voltage at 0.005V increment
- vTTCPU: Adjustable I/O voltage at 0.00625V increment
- vCCSA: 255-step system agent voltage control
- vDRAM Bus: 160-step Memory voltage control
- vPCH: 96-step Chipset voltage control
- vCPU_PLL: 48-step CPU & PCH PLL voltage control
SFS (Stepless Frequency Selection)
- BCLK/PEG frequency tuning from 80MHz up to 300MHz at 0.1MHz increment
Overclocking Protection:
- ASUS C.P.R.(CPU Parameter Recall)
Key specification:
Form Factor: ATX, 12”x 9.6” (30.5cm x 24.4cm)
CPU: Intel® Socket 2011 for 2nd Generation Intel® Core™ i7 Processor Extreme Edition, Supports Intel® Turbo Boost Technology 2.0
Chipset: Intel® X79 Express Chipset
Memory: 8 x DIMM, Max. 64GB, DDR3 2400(O.C.)/2133(O.C.)/1866/1600/1333/1066 MHz, ECC, Non-ECC, un-buffered Quad channel Memory
Expansion Slots: 3 x PCIe 3.0 x16 slots (dual@x16/x16; triple@x16/x8/x8), 1 x PCIe 3.0 x16 slot (PCIe x16_3@x8 speed), 2 x PCIe 2.0 x1 slots
Multi-GPU: Supports NVIDIA® 3-Way SLI™ and AMD® Quad-GPU CrossFireX™ Technology
Storage 1: Intel® X79 Express Chipset: 2 x SATA 6Gb/s ports with RAID 0,1,5 and 10 support, 4 x SATA 3Gb/s ports with RAID 0,1,5 and 10 support
Storage 2: Marvell® 9128 SATA controller: 2 x SATA 6Gb/s ports
Storage 3: ASMedia® 1061 SATA controller: 2 x Power eSATA 6Gb/s ports
LAN: Intel® 82579V Gigabit LAN controller
Audio: Realtek® ALC 898 8-channel High Definition Audio CODEC Supports 192kHz/ 24bit BD Lossless Sound
USB: 3 x ASMedia USB 3.0 controllers: 2 x USB 3.0/2.0 ports at mid-board for front panel support: 4 x USB 3.0/2.0 ports at back panel with 1 additional VIA SuperSpeed USB
USB: Intel®X79 Express Chipset: 12 x USB 2.0/1.1 ports (6 ports at mid-board, 6 ports at back panel)
IEEE 1394: None
BT & WiFi: Bluetooth V2.1+EDR with ASUS BT GO! Utility, NO WIFI
Bios Features: 64 Mb Flash ROM, UEFI BIOS, PnP, DMI2.0, WfM2.0, SM BIOS 2.6, ACPI 2.0a, Multi-language BIOS, ASUS EZ Flash 2, ASUS CrashFree BIOS 3
Manageability: WfM 2.0, DMI 2.0, WOL by PME, WOR by PME, PXE
*This motherboard is ready to support PCIe 3.0 SPEC
Back Panel I/O Ports:
1 x Bluetooth module
1 x Optical S/PDIF Output port
1 x LAN (RJ-45) port
2 x Power eSATA 6G ports
4 x USB 3.0/2.0 ports (blue)
6 x USB 2.0/1.1 ports
1 x USB BIOS Flashback button
8-channel Audio I/O
Internal I/O Connectors:
1 x USB 3.0/2.0 connector support additional 2 USB ports (19-pin)
3 x USB 2.0/1/1 connectors support additional 6 USB ports
4 x SATA 6Gb/s connectors
4 x SATA 3Gb/s connectors
1 x CPU Fan connector (4-pin)
1 x CPU Opt Fan connectors (4-pin)
4 x Chassis Fan connectors (4-pin)
1 x Front panel audio connector(AAFP)
1 x S/PDIF Out header
1 x Clear CMOS button
1 x 24-pin EATX Power connector
1 x 8-pin EATX 12V Power connector
1 x System Panel (Q-Connector)
1 x MemOK! Button
1 x EPU switch
1 x TPU switch
1 x PWR button
1 x Reset button
In The Box:
4 x Serial ATA 6Gb/s cables
2 x Serial ATA 3Gb/s cables
1 x ASUS 3-Way SLI bridge connector
1 x ASUS SLI bridge connector
2 in 1 Q-connector
I/O Shield
User's manual
Drivers
ASUS Utilities
ASUS Update
Anti-virus software (OEM version)
Was £229.99 Inc. VAT
Only £191.98 inc VAT.
ORDER NOW
Gigabyte X79-UD3 Intel X79 (Socket 2011) DDR3 Motherboard @ £144.98 inc VAT
GIGABYTE X79 series motherboards are designed to unite unrivalled desktop PC performance with a new level of flexibility and hardware control. Based on the latest Intel® X79 Express Chipset, supporting the new LGA 2011 Intel® Core™ i7 processors, GIGABYTE X79 series motherboards bring DIY builders to a new area of performance-oriented computing. GIGABYTE X79 series motherboards are the first to take advantage of the exclusive GIGABYTE 3D Power, an all new hardware and software-based Digital Power Engine for both the PWM and Memory that delivers unprecedented power
Specification
- Support for Intel Socket 2011
- X79 Chipset
- XL-ATX Form Factor (305x 244)
- PCI Express Gen3 Support
- 4x PCI-E 3.0 x16 slots (X16, X16, X8, X8)
- 1x PCI slot
- 2x PCI-E x1 slots
- Memory Supported: DDR3 Quad Channel 2133/2000/1600/1333
/1066/800
- Memory Socket: DDR3 4x
- USB ports: 4x USB 3.0 (F2, B2), x14 USB 2.0 (F6, B8)
- SATA 6GB/s ports: 6
- SATA 3GB/s ports: 4
- eSATA 3GB/s ports: 2
- RAID: RAID 0/1/5/10
- Audio: ALC889 W/Dolby
- LAN: 1x GbE LAN Intel
- BIOS: Dual UEFI
Was £174.99 Inc. VAT
Only £144.98 inc VAT.
ORDER NOW
Gigabyte GA-970A-DS3 (Socket AM3+) DDR3 Motherboard @ £51.98 inc VAT
The 970A-DS3 motherboard is designed to offer a stable, high-speed platform for delivering amazingly fast data transfer via the GIGABYTE 333 onboard acceleration technologies. Featuring the USB3.0 controller, AMD 900 series motherboards allow users to take advantage of super fast USB transfer rates of up to 5Gbps, delivering 10x faster data transfer compared to USB 2.0. Utilizing the industry's first Serial ATA Revision 3.0 solution via AMD SB950 chipset, GIGABYTE AMD 900 series motherboards offer native 6 ports of next generation high speed data storage devices support with data transfer speeds of up to 6 Gbps with RAID 0, 1, 5, 10. The AMD 900 series motherboards introduce a unique hardware design with lower resistance fuses for ensuring lower voltage drops and providing more stable and plentiful power delivery. All USB ports also benefit from a 3x power boost for better power delivery to power hungry USB devices.
• On/Off Charge Technology
• Get Ready for New Generation of 32nm AMD AM3+ CPU
• Supports next generation of 45nm AMD AM3 CPU
• SATA 6 Gbps Support
• USB 3.0 Support
Form Factor: ATX
Graphics Interface: PCIe 2.0 (x16)
CPU Socket: AM3+
SLI: No
QPI Speed: N/A
System Bus: 4800MT/s
Hybrid SLI: No
Chipset: AMD 970
Hybrid Crossfire: No
Memory Type: DDR3
Crossfire: No
Memory Channel: Dual
Water Cooled: No
Memory Type (ECC): Non-ECC
SATA: SATA III - 6Gb/s
Memory Type (R/U): Unbuffered
RAID: SATA
Memory Speed (Mhz): DDR3 - 1066, DDR3 - 1333, DDR3 - 1600, DDR3 - 1866, DDR3 - 2000(OC)
Expansion Slots: 2 x PCI (32 bit), 1 x PCIe 2.0 x16, 1 x PCIe 2.0 x16 (x4 Bandwidth), 3 x PCIe x1
Memory Capacity: 32GB
Internal I/O: 1 x 24pin (V), 1 x 4pin (V), 1 x FP Audio Header, 6 x SATA III - 6Gb/s, 1 x SPDIF-Out Header, 3 x USB 2.0 Header
Graphics On Board: No
Back Panel: 1 x 10/100/1000 (LAN), 1 x Line In, 1 x Line Out, 1 x Mic In, 1 x PS/2 Keyboard/Mouse Combo, 6 x USB 2.0, 2 x USB 3.0
Was £59.99 Inc. VAT
Only £51.98 inc VAT.
ORDER NOW
"Titan 8200a Krypt PRO" AMD Bulldozer 4.20GHz Quad Core System @ £531.97 inc VAT
The "Titan 8200a Krypt PRO" features a AMD Bulldozer FX-4 Quad Core 4170 4.20GHz Processor, combined with a selection of high performance, handpicked components designed to meet your desire for the perfect gaming system. The "Krypt PRO" featuress the faster AMD 4170 CPU, 8GB of Vengeance RAM and a massive 2TB hard drive over the standard "Krypt" system. All these additions combine to make a fantastic gaming system ready for action!
Why Should You Buy This System?
- Includes the superb AMD Bulldozer FX-4 Quad Core 4170 4.20GHz Processor
- Choose from a selection of graphics cards to meet your performance needs
- 8GB of high performance gaming memory guarantees the smoothest possible experience when multitasking and ensures you never have a break in the action
- Massive 2TB Hard Drive
- 8 Hours stressed tested and quality controlled
- Precision built and cabled by Overclockers UK expert technicians
- All systems with an operating system selected ship out with a pre-installed 180 day trial of Panda Antivirus 2012
System Specification
- Case: Corsair Carbide 300R Case (default choice, options available)
- Power Supply: OCZ ZS 650w PSU
- CPU: AMD Bulldozer FX-4 Quad Core 4170 4.20GHz Processor
- Motherboard: AMD 760G Chipset (AM3+) Motherboard
- RAM: 8GB DDR3 1600MHz Dual Channel Kit
- Hard Drives: 2TB HDD
- Graphics Card: AMD 760G Onboard (default choice, options available)
- Sound: 7.1 Channel Sound (On-Board)
- Optical Drive: OcUK 22x DVD±RW SATA ReWriter (Black)
- Cooler: Cooler Master Hyper 212 EVO CPU Cooler
Service Package
- Full 12 Month collect and return warranty
- Each specification is assembled from handpicked components for compatibility and stability
- Telephone, web note and forum technical support
Is this System for You?
If crazy speed is what you crave in a gaming system then the "Krypt PRO" is for you. Quad core performance at 4.20GHz!
Note - If you would like to make a small change to the specification call our sales team on 0871 200 5052 and they will be happy to help.
* No OS systems are fully tested with the same extensive methods as systems chosen with an operating system. Including tests such as CPU, memory and GFX stress tests. All no OS systems are formatted completely before shipping.
*Please allow between 24 and 48 hours for your system to be built and configured. This may take longer during busier periods.
Was £581.976 Inc. VAT
Only £531.97 inc VAT.
ORDER NOW
· Fan Xpert+
· Network iControl
· USB 3.0 Boost
· AI Suite II
Innovations:
Spec details:
Model
P8Z77-V LX
Chipset
Z77
Power Phase
DIGI+ VRM 4+1 Phase
Graphics
1*PCIe 3.0 x16 slot
1*PCIe 2.0x16
VGA
HDMI/DVI/RGB
YES
SLI/CrossFire
CrossFireX
PCI
3
PCIex1
2
Storage
2*SATA 6Gb/s
4*SATA 3Gb/s
LAN
1*Realtek Gb LAN
1394
N/A
USB
4*USB 3.0
10*USB 2.0
Wi-Fi Support
N/A
Audio
ALC887
Accessories
2*SATA 6G cable
DIGI+VRM
Network iControl
Fan Xpert+
USB 3.0 Boost
AI Suite II
BIOS
UEFI BIOS
Form Factor
ATX
Was £99.99 Inc. VAT
ORDER NOW
CPU
- Digi Power Design
Chipset
- Intel® Z77
Memory
BIOS
Graphics
Audio
LAN
- Broadcom BCM57781
- Supports PXE
- 2 x PCI slots
SATA3
USB 3.0
Connector
- 1 x IR header
- CD in header
- 1 x HDMI Port
- 1 x DisplayPort
Unique Feature
- F-Stream
- ASRock SmartView
- ASRock XFast USB
- ASRock XFast LAN
- ASRock XFast RAM
- Hybrid Booster:
- ASRock U-COP
- Good Night LED
Smart Switch
Support CD
Accessories
- 4 x HDD Screws
Hardware Monitor
Form Factor
OS
Certifications
- FCC, CE, WHQL
ORDER NOW
Key specification:
IEEE 1394: None
8-channel Audio I/O
1 x MemOK! Button
1 x EPU switch
1 x TPU switch
1 x PWR button
1 x Reset button
In The Box:
2 in 1 Q-connector
I/O Shield
User's manual
Drivers
ASUS Utilities
ASUS Update
ORDER NOW
Specification
- X79 Chipset
- 1x PCI slot
- 2x PCI-E x1 slots
/1066/800
- BIOS: Dual UEFI
ORDER NOW
• USB 3.0 Support
Form Factor: ATX
CPU Socket: AM3+
SLI: No
QPI Speed: N/A
Hybrid SLI: No
Chipset: AMD 970
Memory Type: DDR3
Crossfire: No
Water Cooled: No
RAID: SATA
Was £59.99 Inc. VAT
ORDER NOW
Service Package
ORDER NOW
