Hey guys,
As you can imagine I've read a **** tonne of reviews for a whole host of keyboards and I don't seem any closer to a decision.
I have a few keyboards in mind but I just don't know which to go for.
The first is a Razer Blackwidow Ultimate.
I really like the look of this and pretty much would have bought it without hesitation but there are plenty of reviews on line documenting keys sticking, it seems a fairly common fault. Hence my dubiousness. This along with your warranty being void if you remove a key is more than a little off putting.
Second is a Corsair K90.
Another one I really like apart from the macro keys! There is no way of removing them obviously so Its something I'd have to get used to. I wouldn't mind if it was just a row or two and they were mechanical but it's also the mix of key types that puts me off a little.
Lastly there is one of the Logitech keyboards (G110 or G510)
I don't mind the look of either of these but I'm not sure how much use I would get out of the screen on the G510. Which brings it down to the fact that neither of them are mechanical.
I'm looking for a decent keyboard for gaming and occasionally other typing work, with a blue back light and a good reliability record!
Thanks in advance!
Thanks in advance!
