- 8 Sep 2003
- Was 150 yds from OCUK - now 0.5 mile; they moved
My Antec rep is sat with me, I have just tied to to the chair and I'm not letting him go until he helped me to achieve amazing pricing for you lovely forums. So he gave in and offered the following deals.
Antec High Current Gamer 620W '80 Plus Bronze' Power Supply @ £59.99 inc VAT
Antec’s High Current power supplies are the perfect PSU combination of power and efficiency. The High Current Gamer features a high-power +12V rail and special heavy-duty High Current connectors and cabling that supply extreme levels of power, and also superb efficiency thanks to 80 PLUS® Bronze certification and Active PFC. Highest-quality gold-plated connectors, Japanese-brand capacitors and quiet 135 mm double ball bearing fans complete the package. If loads of power, High Current engineering and extreme efficiency are what you’re after, the High Current Gamer is the PSU for you.
- 80 PLUS® Bronze certified – up to 88% efficient
- High Current +12V rail for graphics card compatibility and over
current protection (OCP) for safety
- Quiet 135 mm double ball bearing cooling fan
- All Japanese brand capacitors for reliability
- Gold-plated High Current terminals for optimal conductivity
- ATX12V version 2.3 and EPS12V version 2.91 compliant
- Full industrial-grade protection:
- Over current protection (OCP), Over voltage protection (OVP), Short circuit protection (SCP), Over power protection (OPP)
- Active PFC with PF: 0.99 – less harmonic pollution and more
savings on corporate electrical bills
- MTBF: 100,000 hours
- Meets 2010 EUP requirement: 5Vsb < 1W
- Safety: cUL, TÜV, CE, CB, FCC, C-TICK, CCC, BSMI, Gost-R
- Weight: 4.4 lb / 2 kg
- Dimensions: 86 mm (H) x 150 mm (W) x 160 mm (D)
Was £79.99 Inc. VAT
Only £59.99 inc VAT.
ORDER NOW
Antec High Current Gamer 520W '80 Plus Bronze' Power Supply @ £49.99 inc VAT
Was £62.99 Inc. VAT
Only £49.99 inc VAT.
ORDER NOW
Antec High Current Gamer 400W '80 Plus Bronze' Power Supply @ £38.99 inc VAT
Was £44.99 Inc. VAT
Only £38.99 inc VAT.
ORDER NOW
Antec High Current Gamer 750W Quad Rail '80 Plus Bronze' Power Supply @ £82.99 inc VAT
Making quad rail power and highly advanced power supply design available at a popular wattage, the HCG-750 features special High Current connectors and heavy-duty cabling, earning it NVIDIA® SLI®-Ready and ATI™ CrossFire™ certifications. At the same time the HCG-750 is also 80 PLUS® Bronze certified for efficiency, and features active PFC with a swift, quiet 135 mm double ball bearing fan so you know you're getting not only High Current, but also high efficiency and excellent cooling. If loads of power, High Current engineering and exceptional efficiency are what you're after, the HCG-750 is the perfect PSU for you.
- 750 watts of Continuous Power
- NVIDIA&® SLI®-Ready certified, ATI CrossFire™ certified
- 80 PLUS® Bronze certified - up to 88% efficienct
- Quad High Current +12V rails with high maximum load for better graphics card compatibility
- Quiet 135mm double ball bearing cooling fan with low start voltage
- Four gold-plated 8 (6+2)-pin PCI-E connectors for multiple-graphics card configurations
- ATX12V version 2.3 and EPS version 2.91 compliant
- Universal Input - works on any 100V - 240V grid
- Active PFC with PF: 0.99 - less harmonic pollution, greater efficiency
- Full suite of industrial grade protection:
- Over voltage protection (OVP)
- Short circuit protection (SCP)
- Over power protection (OPP)
- Over temperature protection (OTP)
- Safety: cUL, TUV, CE, CB, FCC, C-TICK, CCC, BSMI, Gost-R
- AQ5 Antec Quality 5-year limited warranty on parts and labour
Was £99.98 Inc. VAT
Only £82.99 inc VAT.
ORDER NOW
Antec High Current Gamer M 520W "80+ Bronze" Modular Power Supply @ £69.98 inc VAT
Antec's HCG M power supplies are the perfect combination of power and efficiency. The HCG M features special heavy-duty High Current connectors and cabling that supply extreme levels of power, and superb efficiency thanks to 80 PLUS® Bronze certification and Active PFC. Highest-quality connectors, Japanese-brand capacitors, and a quiet 135 mm double ball bearing fan complete the package. The HCG-520M features High Current Cable Management and 10-pin modular connectors. If loads of power, High Current engineering and extreme efficiency are what you're after, the HCG M is the PSU for you.
Features:
- 520 watts of Continuous Power
- 80 PLUS® Bronze certified — up to 87% efficient
-High Current Hybrid Cable Management — special 10-pin and 5-pin modular connectors for High Current rail
- Quiet 135 mm Double Ball Bearing cooling fan
- Stealth Wires: all wires darkened for minimal visibility in chassis
- Thermal Manager: an advanced low voltage fan control for optimal heat & noise management
- Up to 90% power available on +12V rail
- ATX12V version 2.32 and EPS12V version 2.92 compliant
- Heavy-duty protection circuitry on all rails prevents damage from a variety of dangers:
- Over Current Protection (OCP)
- Over Voltage Protection (OVP)
- Under Voltage Protection (UVP)
- Short Circuit Protection (SCP)
- Over Power Protection (OPP)
- Surge & Inrush Protection (SIP)
- AQ5 — Antec Quality 5 year limited warranty on parts and labour
- MTBF: 100,000 hrs
- POWER SUPPLY CONNECTORS ASSORTMENT:
- 1 x 24(20+4)-pin
- 1 x 8(4+4)-pin ATX12V/EPS12V
- 2 x 8(6+2)-pin PCI-E
- 5 x SATA
- 4 x Molex
- 1 x Floppy
- Safety Approvals: UL, cUL, CE, TÜV, CB, FCC, CCC, C-Tick, BSMI
- Net Weight: 1.8 kg / 4.0 lbs
- Size:
- 86 mm (H) x 150 mm (W) x 160 mm (D)
- 3.4" (H) x 5.9" (W) x 6.3" (D)
Was £73.99 Inc. VAT
Only £69.98 inc VAT.
ORDER NOW
Antec High Current Gamer M 620W "80+ Bronze" Modular Power Supply @ £76.99 inc VAT
Elite power meets unrivaled performance
Antec's HCG M power supplies are the perfect combination of power and efficiency. The HCG M features special heavy-duty High Current connectors and cabling that supply extreme levels of power, and superb efficiency thanks to 80 PLUS® Bronze certification and Active PFC. Highest-quality connectors, Japanese-brand capacitors, and a quiet 135 mm double ball bearing fan complete the package. The HCG-620M features High Current Cable Management and 10-pin modular connectors. If loads of power, High Current engineering and extreme efficiency are what you're after, the HCG M is the PSU for you.
Features:
620 watts of Continuous Power
AQ5 — Antec Quality 5 year limited warranty on parts and labor
MTBF: 100,000 hrs
- 1 x 24(20+4)-pin
- 6 x SATA
- 6 x Molex
- 1 x Floppy
Net Weight: 1.9 kg / 4.2 lbs
Size:
Was £82.99 Inc. VAT
Only £76.99 inc VAT.
ORDER NOW
Antec 1100 Eleven Hundred Ultimate Gaming Tower Case - Black @ £89.99 inc VAT
The Antec Eleven hundred is the new beast in the Hundred Series range, with a price that beats the competition to the ground with features and technology that does truely astound.
- 0.8mm SECC Constuction
- Perforated, quick release front bezel
- Enlarged CPU cutout
- Windowed side panel and optional fan mounts
- Supports up to XL-ATX Motherboards
- 11 drive Bays
- Rubber grommetted cable routing holes
- Fits all Antec Kuhler H20 CPU Coolers
- Supports GPU's up to 330mm
- 9 Expansion Slots
- Front I/O Ports: Audio in/output / 2 x USB3.0 / 2 x USB2.0
- Tool-less 3.5" Drive bays x 6
- Easy install 2.5" Drive bays x 2
- Tool-less 5.25" Drive Bays x 3
- Top Cooling: 1 x 200mm Blue LED Fan
- Side Cooling: 1 x 120mm Fan (optional) - behind the motherboard to cool back of CPU
- Rear Cooling: 1 x 120mm Fan
- Front Cooling: 2 x 120mm Fans (optional)
- Internal Cooling: 2 x 120mm Fans (optional)
- Side Cooling: 2 x 120mm Fans (optional)
- 3 x Fan Filters
- 3 Year Warranty
Was £99.99 Inc. VAT
Only £89.99 inc VAT.
ORDER NOW
Antec Kúhler H2O 620 CPU Watercooler (Socket Intel LGA 775 / 1155 / 1156 / 1366 / AMD AM2 / AM3 / AM2+ / AM3+) @ £49.99 inc VAT
Finally, there is a liquid cooler for the rest of us. The Antec KÜHLER H2O 620 delivers high-performance liquid cooling for your CPU in a quick, easy-to-install package. Unlike traditional liquid cooling systems, this self-contained unit comes prefilled and requires no maintenance. The voltage-controlled 120 mm fan, 3rd generation copper coldplate and airflow-enhancing low-profile pump ensure efficient cooling, while the estimated 50,000 hour pump lifetime means this cooler is even likely to outlast the system it cools. Easy-bend flexible tubing allows the KÜHLER H2O 620 to be installed in nearly any orientation regardless of the internal configuration of the case. Finally, the KÜHLER H2O 620 comes with peace of mind in the form of an industry-leading Antec Quality 3 year limited warranty on parts and labour. Take your PC’s Quiet Computing™ to the next level with liquid cooling performance at a price that rivals aftermarket air coolers.
- CPU Socket Compatibility: Intel LGA 775, 1155, 1156, 1366, AMD AM2, AM3, AM2+, AM3+
- Low profile pump ensures exceptional liquid circulation while preserving internal airflow
- Easy-bend tubes for maximum flexibility in radiator positioning
- Intelligent noise / speed control fan for quiet, efficient cooling
- Latest generation copper cold plate for optimal conduction
- Cooling Liquid - Safe, environmentally-friendly, anti-corrosive
- Fan Speed: 1450 - 2000 RPM
- Tubing Length: 330 mm / 13.0"
- Radiator Dimensions: 151mm x 120mm x 27mm
- Fan Dimensions: 120 mm x 25 mm / 4.7" x 1.0"
- AQ3 - Antec Quality 3-year parts and labour warranty
Was £54.99 Inc. VAT
ORDER NOW
Was £79.99 Inc. VAT
ORDER NOW
Was £62.99 Inc. VAT
ORDER NOW
Was £44.99 Inc. VAT
ORDER NOW
Was £99.98 Inc. VAT
ORDER NOW
Features:
- MTBF: 100,000 hrs
- 1 x 24(20+4)-pin
- 5 x SATA
- 4 x Molex
- 1 x Floppy
- Size:
Was £73.99 Inc. VAT
ORDER NOW
Features:
MTBF: 100,000 hrs
- 1 x 24(20+4)-pin
- 6 x SATA
- 6 x Molex
- 1 x Floppy
Size:
Was £82.99 Inc. VAT
ORDER NOW
- 11 drive Bays
- 9 Expansion Slots
- 3 x Fan Filters
- 3 Year Warranty
Was £99.99 Inc. VAT
ORDER NOW
Was £54.99 Inc. VAT
ORDER NOW
