Hi there, as my title says ive finally decided to pull the trigger on watercooling after getting a tax refund. I have a budget of £300 to watercool my pc would like to cool the gpu but that could be done at a later date. So pretty much I need everything but a few conditions, I dont like pump/res combos or id buy the pre made kits also I dont want a bay res. So if you can spec me something that includes a 240 rad max cba to mod my case to accomadate a 360 but could fit a 240 and 120 easily.
Needs :-
CPU block
Tubing (Clear Black and White yes i want all 3 colours as i want to try something with alternating colours)
Fittings (not sure on how many and which type of these to get)
Coolant (thinking of going red)
Pump + pump top.(dont want a combo)
Res (prefer a tube res)
Fans
Cutters
Jumper
*GPU block and backplate budget allowing will add at a later date if not)*
and anything else I may have missed off.
I look forward to any help that is received.
Needs :-
CPU block
Fans
Cutters
Jumper
quiet pump and you are also probably looking to upgrade the loop at some point from looking at what you are saying there. Not worth skimping on the pump to save a few £. You would only need a 240 rad for single gpu and cpu anyway so the list that has been shown up there already looks good
Dreading the day I have to undo my compression fittings :/
