- 30 Oct 2007
Hello. I just received my graphics card, which was fixed, but now I have another, even bigger problem!
My PC was running fine for a few days, when some time on Wednesday it powered off for no reason. I tried to turn it back on but the power light only came on for a second (like when you unplug the PC and there is still a tiny bit of power still in the system). I pulled the tower out from under my desk and opened the side, but could not see any problem. I turned it off from the PSU and left it off for a while, in case there was an overheating problem, and after a while it turned on again first time. Thursday it worked fine all day.
But today I left the PC running while I did some DIY, only to come back and find it turned off. I tried to turn it back on but nothing happened, so I unplugged the power lead and left it for a while again (I don't think it could have overheated because it was still pulled out from Wednesday). I tried turning it back on after a while, and the case fans started up, as well as the hard drive, DVD drive and graphics card fans, but the CPU cooler didn't start up. I tried leaving it for a bit, but there were no progress/error beeps, and the computer didn't boot.
I couldn't turn it off by holding down the power button, and had to switch it off at the PSU. When I have tried turning it on since either nothing will happen, or the same as above.
I have tried a new power lead, and tried a different socket, but nothing changes. I also unplugged one the case fans and removed the repaired graphics card, in case there was a power issue, but that didn't change anything either.
Does anyone have any idea what could be at fault, and any ideas how I could further test to see what the problem is?
Sorry for any spelling/typing errors, I am using my mum's laptop and the keyboard is full of crumbs!
