28 Apr 2012 at 12:01 #1 jumeeno jumeeno Associate Joined 20 Nov 2011 Posts 449 My FD Define Mini has a USB3 front header straight to motherboard... but my motherboard does not have this feature (just 2 x USB3s on back panel). Therefore, not sure how to get USB3 working on the front panel - any suggestions?
28 Apr 2012 at 12:14 #2 King Damager King Damager Soldato Joined 16 Nov 2010 Posts 16,511 Location Swimming in a lake I believe you can't unfortunately. kd
28 Apr 2012 at 12:15 #3 Nightglow Nightglow Soldato Joined 19 Jan 2010 Posts 6,766 Location South West Just need to add a USB 3.0 pci-e card then plug usb 3 header cable into that. http://www.overclockers.co.uk/showproduct.php?prodid=CA-126-SV http://www.overclockers.co.uk/showproduct.php?prodid=CC-002-AK Last edited: 28 Apr 2012
28 Apr 2012 at 12:20 #4 RJC RJC Don Joined 29 May 2005 Posts 29,104 Location Kent It might be worth contacting the manufacturer and they might send some USB 2 connectors and kep the USB 3 when you upgrade later.
28 Apr 2012 at 14:09 #6 bremen1874 bremen1874 Soldato Joined 20 Oct 2008 Posts 12,083 You can buy adapter cables that allow you to pass the cables out of the case and use the back panel USBs. I'd have thought that OcUK would sell a suitable cable, but they don't appear to.
28 Apr 2012 at 16:02 #7 Alloneword Alloneword Associate Joined 16 Oct 2008 Posts 231 Cough Cough, contact me via PM and I may be able to help you find what you need. Thx RJC Last edited: 28 Apr 2012
28 Apr 2012 at 16:22 #8 RJC RJC Don Joined 29 May 2005 Posts 29,104 Location Kent Alloneword said: Hopefully i'm not breaking any rules here, ut another site sells what you need. All1 Click to expand... I would remove the link before a mod see's
30 Apr 2012 at 00:48 #9 Alloneword Alloneword Associate Joined 16 Oct 2008 Posts 231 Only 1 left in stock where i got mine from. All1
