Hi all. I'm stuck between 2 main choices in my next upgrade path, any help,comments or ideas would be appreciated.
Basically its a toss-up between 1155 and 2011 platforms. 1155 is slightly cheaper but i can't see any upgrade path from ivy bridge later on.. whereas lga 2011 has the potential for ivy bridge-e later on and maybe more..
My current setup
CPU: i7 920 C0 @ 3.9Ghz
Heatsink: CoolerMaster V6GT
Mobo: Asus P6T Deluxe (v1)
RAM: 9Gb OCZ Gold 1600Mhz 8,8,8,24,1T
GPU1: Asus GTX580 Matrix Platinum
GPU2: Asus GTX520 Silent
Soundcard: Asus Xonar Essence STX
SSD: OCZ Vertex 2e 60Gb
HDD: 2x WD Caviar Black 1Tb RAID-0
PSU: OCZ ZX1000
Case: NZXT H2
Main uses apart from internet browsing and music listening: Gaming, music production and i'm looking into VMs
Reasons for upgrade
I bought the RAM, Mobo and CPU within the first month of X58 release, it's been strong and loyal but it's old and has it's quirks.
Component upgrade
Option 1: X79 - LGA 2011
CPU: i7-3820
Heatsink: Phanteks PH-TC14PE
Mobo: Asus X79 Sabertooth
RAM: 16Gb Samsung Green
SSD: Crucial RealSSD M4 256Gb (unless there is a better suggestion)
Option 2: Z77 - LGA 1155
CPU: i7-3770K
Mobo: Asus Z77 Sabertooth
Asus are my favourite brand as I've found them brilliant in terms reliability and price|performance ratio. Therefore i will be sticking with them for the motherboard choice, their Sabertooth model (so long as the system will be able to sleep
The SSD choice will probably change, will need to check more reviews and potential issues with the drive. It will be used for boot, apps and games.
TIA
My current setup
PSU: OCZ ZX1000
Case: NZXT H2
Reasons for upgrade
- CPU is hot and not a great overclocker.
- Due to the motherboard, SSD and possibly the overclock settings; i am unable to recover the PC from sleep mode.
- POST and the overall boot speed is so extremely slow.
- USB3.0
- SATA 6GB/s
- Next year i will be buying a house, my annual PC upgrade budget will be pretty much destroyed
Component upgrade
CPU: i7-3820
CPU: i7-3770K
TIA
