- 19 Aug 2011
-snip-
Just for the record, I wasn't comparing to WoW directly, more the flood of clones that very obviously follow it's formula.
I don't know how other people are thinking of this game, but I'm thinking of it like an Elder Scrolls/Fallout type game. Yes, there's a main plot, but what happens if I wander over there...I assume there will be a bigger story. Remember the plot in GW1 doesn't really get going until halfway through the game, while it's considerably shorter than GW2 (I'm just thinking of vanilla GW btw) there's still plenty of time for there to be an intricate plot while we're all still under lvl20 out of 80 levels.
I disagree about the races not being distinct with their own stories. I've only mainly played humans so far but I know the lore is in place and full for all the races, they all have their own personality and back story. It's all explained in the starting areas too, even the feel of the starting areas seems to give a good feel for the races.
The dynamic events are just that, dynamic. Yes, there might be events that are "collect apples" but it's not just go there, do that. It's how many people are involved, how much you contribute, what happens if you succeed, what happens if you fail. If you go to a village and start helping someone, will you be able to go back after or will centuars have taken over, if you're spending 10 minutes defending somewhere from enemies, will you succeed or will you then have to take it back? If you drive back enemies, will they then send a huge boss that you have to kill? That's very different from static "go kill 10 boars" quests where you go do it and have no impact on the world.
I'm in game at the moment half afk to write this and while I'm doing it, centuars have attacked the cave outpost I'm stood in.
Bhavv, I think he means like in the first game where if you clicked a spot on the ground, your character would move there. I always turned that off anyway, I just found it annoying.
TheMeekon, that's to do with being bolstered, if your character was max level, you'd be using your own gear.
If you do WvWvW you'll be using all your own stuff anyway, just your hp and power etc gets bolstered.
