Corsair Deals! Ideal for the new IvyBridge CPU's
8 Sep 2003
Was 150 yds from OCUK - now 0.5 mile; they moved
Corsair Enthusiast Series TX650M High Performance 650W '80 Plus Bronze' Modular Power Supply (CP-9020002-UK) @ £74.99 inc VAT
The Enthusiast Series TXM is part of Corsair’s best price-performance range of power supplies, designed to meet the exacting standards and performance needs of demanding enthusiasts. TXM Series power supplies are ideal for performance enthusiasts who require an affordable, low noise, high-wattage, reliable and highly efficient PSU. Corsair TXM power supply gives the flexibility of using only the cables needed for a clean system build with optimal airflow.
- The latest ATX12V v2.31 and EPS 2.92 standards and it is backward compatible with ATX12V 2.2 and ATX12V 2.01 systems.
- An ultra-quiet double ball-bearing fan delivers excellent airflow at an exceptionally low noise level by varying fan speed in response to temperature.
- 80PLUS Bronze certified, delivering up to 85% energy efficiency at real world load conditions.
- Modular power supply. Universal AC input from 90~264V.
- No more hassle of flipping that tiny red switch to select the voltage input! A dedicated single +12V rail offers maximum compatibility with the latest components.
- Over-voltage and over-current protection, under-voltage protection, and short circuit protection provide maximum safety to your critical system components.
- A five year warranty and lifetime access to Corsair’s legendary technical support and customer service.
- Safety Approvals: UL, CUL, CE, CB, FCC Class B, TÜV, CCC, RCM.
Was £86.99 Inc. VAT
Only £74.99 inc VAT.
ORDER NOW
Corsair Enthusiast Series TX750M High Performance 750W '80 Plus Bronze' Modular Power Supply (CP-9020003-UK) @ £86.99 inc VAT
- Universal AC input from 90~264V. No more hassle of flipping that tiny red switch to select the voltage input!
- A dedicated single +12V rail offers maximum compatibility with the latest components.
Was £96.98 Inc. VAT
Only £86.99 inc VAT.
ORDER NOW
Corsair HX 850W ATX Modular SLI Compliant Power Supply (CMPSU-850HXUK) @ £123.98 inc VAT
Corsair Professional Series power supplies set a new standard by which all premium PSUs must be judged. Designed and engineered using cutting-edge technology, each Corsair Professional Series power supply is built to the highest quality standards, and delivers the features and performance that technology enthusiasts demand.
- Enhanced modular flexible cables enable easier cable routing and increased airflow in the system
- Guaranteed to deliver rated specifications at 50ºC.
- Supports the ATX12V v2.3 and EPS12V 2.91 standards and is backwards compatible with ATX12V 2.01 systems
- Double forward switching circuitry design offers high efficiency, up to 90% under typical load range
- Active Power Factor Correction with PF value up to 0.99 provides clean and reliable power to your system
- Ultra quiet 140mm double ball-bearing fan delivers excellent airflow at an exceptionally low noise level by varying the RPM in response to temperature.
- Over Current/Voltage/Power Protection, Under Voltage Protection, and Short Circuit Protection provide maximum safety for your critical system components
- 105ºC rated industrial grade capacitors provide uncompromised performance and reliability, delivering 4 times the lifespan of conventional 85ºC rated capacitors
- Dimension: 150mm(W) x 86mm(H) x 180mm(L)
- MTBF: 100,000 Hours
- 5-Year Warranty
Was £134.99 Inc. VAT
Only £123.98 inc VAT.
ORDER NOW
Corsair Carbide 300R Mid Tower Case - Black @ £53.99 inc VAT
The Carbide Series™ 300R is a compact expression of the Corsair philosophy: great systems begin with a great case. Open the easy-access side panel to find a builder-friendly design with three tool-free optical drive bays and four tool-free hard drive bays with integrated 2.5” SSD compatibility. There’s room for extra-long graphics cards, and the matte black interior really shows off your gear. Finish off your build with a cable routing system that keeps wires and cables out of sight and out of the airflow path for a clean, uncluttered look.
The 300R keeps your hardware cool with amazing airflow, including a 140mm front intake fan and a 120mm rear exhaust fan. There’s room to add five additional fans, including dual side-panel fan locations that can deliver cool air directly to your graphics cards. And, the dust filters are removable for easy maintenance. Features like these make the Corsair Carbide Series 300R the foundation of your next great system.
- Room for graphics cards up to 450mm long
- USB 3.0 front panel connectors
- Built-in compatibility for SSDs in the four hard drive bays gives you the flexibility you need
- Keep your system cool with up to 7 fan mount locations
- Easily accessible dust filters keep the cool air flowing over your valuable components
- Install or upgrade your CPU heatsink quickly with the easy-access backplate cutout
- Optimize airflow and keep your system neat and tidy using the intelligent cable management system
- Drive Bays: 3 x 5.25" Drive Bays and 4 x 3.5"/2.5" Drive Bays
- Cooling: 1 x 140mm intake fan and 1 x 120mm exhaust fan
- Expansion Slots: 7
- Motherboard Support: ATX & mATX
- Front I/O: 2 x USB3.0 and 2 x Audio
- Dimensions: 19.1" x 8.3" x 17.7"
Was £59.99 Inc. VAT
Only £53.99 inc VAT.
ORDER NOW
Corsair Carbide 500R Midi Tower Case - Black/White @ £82.99 inc VAT
Want even more outrageous cooling flexibility? Step up to the 500R. It adds a 200mm fan mounted on the side panel’s mesh screen for extra GPU cooling, a multi-channel fan controller, and removable and relocateable hard drive cages. The ability to move and remove hard drive cages not only improves airflow — it also allows you to install graphics cards of up to 452mm in length.
Support for USB 3.0 and 2.5” SSDs is built-in. Two USB 3.0 connectors are provided on the front panel and connect directly to motherboards with compatible USB 3.0 headers. Integrated SSD support lets you install 2.5” solid-state drives in any of the hard drive bays, without having to deal with adapters.
The beauty on the inside goes beyond the black-painted interior. Corsair’s innovative cable management system provides a straightforward way to route cables behind the motherboard, not across it where it can interfere with airflow and give your system a cluttered look. And since looks are an important part of any build, you’ll appreciate the ability to turn the front panel fan white LEDs on or off with the push of a button.
- Side panel with mesh fan mount locations
- Dimensions: 20.5” x 8.1” x 20”
- Four 5.25” drive bays
- Six 3.5” hard drive bays with 2.5” compatibility
- Eight expansion slots
- Supports most 240mm dual radiators (15mm spacing)
- Six 120mm/140mm fan mounts
- Four 120mm fan mounts
- Front I/O Ports: 2 x USB3.0, 1 x FireWire, 2 x Audio
- Two-year warranty
Was £92.99 Inc. VAT
Only £82.99 inc VAT.
ORDER NOW
Corsair Obsidian 550D Quiet Midi Tower Case - Black @ £99.98 inc VAT
The Obsidian Series™ 550D has been carefully engineered for noise reduction. The front and side panels are insulated with sound dampening material, and the hard drive trays and fans have soft silicon mounts to absorb vibration. The top and side panel vents are covered for noise reduction if you’re not using them to install your own fans, and even the intakes are angled to reduce air noise.
The rigid, stamped steel and brushed aluminum case holds some remarkable technology that makes it easy to build great systems. There’s built-in USB 3.0 support, and the drive trays work with 2.5” SSDs. The removable hard drive bays allow customization for extra-long graphics cards and maximizing airflow. And, the easy-access side panels come off at the touch of a button for easy upgrades or simply admiring your work.
- Insulated, sound dampening side and front panels
- Six tool-free hard drive trays with integral SSD support and soft silicon sound dampening
- Four tool-free optical drive bays
- Angled air intakes for reduced noise
- Covered vents for noise reduction if additional fans (not included) are not installed
- Front panel USB 3.0 connectors and audio connectors
- Cable routing cutouts with rubber grommets
- Removable, reversible front panel
- One-button side panel removal for quick access
- Matte black interior
- Three 120mm fans
- Top panel is compatible with 240mm radiators for dual-radiator Hydro Series. CPU coolers and liquid cooling systems
- Eight expansion slots for multi-GPU compatibility
Was £109.99 Inc. VAT
Only £99.98 inc VAT.
ORDER NOW
Corsair Vengeance K90 Mechanical Gaming Keyboard @ £86.99 inc VAT
Cherry® MX Red key switches are the best of the best — they provide the sensitivity and low operating force that professional gamers love. Reaction times are ulra-fast and responsive for quicker double and triple taps. The action is predictable and linear unlike lesser gaming keyboards that have a tactile bump or the annoying click of a typist’s keyboard.
Easily access to your most frequently used macros, presets and key combinations even during the most intense action. You can record up to 54 programmable functions accessible from three separate banks, ideal for grouping macros by function, or access. Macros can be created on-the-fly, customized, and activated with a single keystroke.
Our expertly designed anti-ghosting technology provides flawless control even when you're pressing multiple keys at once. The K90 has individual switches with dedicated diodes for each switch so every key press results in an input and is 100% ghost free without tradeoff or compromise.
Typical USB gaming keyboards are limited to the USB standard six-key rollover. The K90 features increased performance with a 20-key rollover implementation on USB at a blazing fast 1ms (1000 reports per second) reporting rate.
The rugged aluminum chassis provides increased durability and stability compared those that are primarily plastic. The stiff suspension chassis and the laser etched keys are made for durability so they won't degrade over time. And the K90 has over 90 LEDs that provide outstanding illumination even in dim light.
Create up to 50 profiles and share, import and export macros with the Vengeance keyboard gaming software. It's a free download at corsair.com.
On-board memory lets you take it with you
36Kb of memory built into the K90 lets you take your customizations and profiles with you and use them on any system.
- Light, responsive Cherry MX Red Mechanical switches for fast, efficient gaming action
- 45g actuation force
- 2mm to actuation and 4mm to bottom
- Rated for 50 million operations
- Gold contacts
- Three banks of eighteen G Macro Keys with Macro Record and Bank Select hot keys
- 36Kb of onboard memory for storing up to three sets of eighteen G keys for gaming on the go
- On-the-fly, macro recording
- Laser-etched, backlit keys with four illumination levels (off, 66%, 75%, and full illumination) selectable from the keyboard
- Six multimedia keys — Stop, Previous, Play/Pause, Next, Mute, Volume Up/Down — with Solid metal, weighted volume “drum roller”
- Windows Lock key for uninterrupted game play
- Metal top plate for increased strength, durability and rigidity
- USB pass-through connector giving easy access to a USB port on the back of the keyboard (USB 2.0/1.1/1.0)
- USB Connector with gold plated contacts
- Selectable report rate: 1000Hz/500Hz/250Hz/125Hz (1ms/2ms/4ms/8ms) response time
- 2m non-tangle cable
- Adjustable feet tilt for optimum personalization and positioning
Was £99.99 Inc. VAT
ORDER NOW
Corsair Vengeance M60 5700dpi Laser Gaming Mouse @ £44.99 inc VAT
You get maximum precision and response from the Avago ADNS-9500 LaserStream™ Gaming Sensor, even on high resolution displays. Outpace and dominate opposing players with less accurate or slower gaming mice.
Superior ergonomics and a dedicated sniper button will make the M60 laser gaming mouse your favorite weapon of mass destruction. It's functional design and soft-touch surfaces are comfortable in your hand, even for extended hours gaming sessions. The dedicated sniper button automatically lowers your DPI so that you can quickly adjust your aiming precision and precisely locate shots.
A unibody aluminum frame is the secret behind the M60's low weight, high rigidity, and optimal mass distribution. It also has three adjustable tuning zones, allowing you to customize your mouse's weight to have just the exact feel you want.
When the action is fast and furious, you are constantly moving and repositioning your mouse. The M60's lift detection provides high precision tracking and reliable cursor placement even when lifted off of the mousing surface.
Tune the performance for your desktop surface by choosing between four response times — 1000Hz, 500Hz, 250Hz, or 125Hz (1ms, 2ms, 4ms or 8ms).
The solid metal, rubberized scroll wheel doesn't just feel great — it gives you the precision you need when selecting weapons. Precise tactile feedback and accuracy help make sure that you select the right weapon every time.
- 5700 DPI — Avago ADNS-9500 LaserStream Gaming Sensor
- Adjustable DPI in 100 DPI increments
- 1000Hz/500Hz/250Hz/125Hz (1ms/2ms/4ms/8ms) selectable response time
- Tracking up to 165 inches per second, up to 30g acceleration, and automatic frame rate control
- Adjustable lift distance — five selectable levels to fit your play style
- Surface quality detection
- 8 individually programmable buttons
- Side mounted sniper button provides user settable DPI change while pressed for enhanced precision targeting
- Comfortable ergonomic design with soft-touch surfaces and grip improving textures
- Omron left and right click switches rated for eight million operations
- Aluminum metal frame and base for improved rigidity and mass distribution
- Solid metal, weighted scroll wheel with rubberized scroll surface for improved finger traction control and feel
- Ultra Low Friction PTFE pads for smooth performance and accurate gliding
- 1.8m lightweight non-tangle cable
Was £54.99 Inc. VAT
Only £44.99 inc VAT.
ORDER NOW
Corsair Vengeance 1300 Professional Gaming Headset @ £48.98 inc VAT
If you have a high-end sound card, the Vengeance 1300 will do it justice. If your audio card has CMSS™-3D or a similar 3D audio system, you’ll hear the subtle midband positional cues that you need to enjoy accurate 3D audio and play your best. Is your enemy behind you and to the left, or to the right? Are they behind a wall, or do they have you in their crosshairs? Gaming sound designers work hard to make audio sound great, and your high-end sound card and Vengeance 1300 are a great combination for making that happen.
The results of obsessive audio engineering
The massive 50mm drivers greatly reduce the overloading and distortion that can occur with gaming headsets that use 40mm drivers. You get more accurate sound reproduction (particularly for the all-important low-frequency effects). You hear more audio, more cleanly, and you get a competitive advantage.
The extra-wide, extra deep earcups don’t just help things sound great — they feel better, too. Customize your comfort with your choice of the included microfiber or synthetic leather covers. Both use memory foam earpads for a comfortable, reliable fit that conforms to the shape of your head without binding or pinching.=
The circumaural, closed-back design blocks distracting sounds and keeps your head in the game, and the extra-large inline volume and microphone control is easy to grab and use when the action heats up you don't need to take your eyes off the screen.
Whether you’re barking instructions to your teammates or chatting with old friends, you deserve to be heard. The unidirectional, noise-cancelling microphone is tuned to capture your voice loudly and clearly, while screening out distracting background noises. And, it flips out of sight when you’re not using it.
You need more than just dramatic audio. You need the comfort that allows you to play or talk for hours without thinking about what’s on your head. You need fidelity that gives you a listening experience that’s not just immersive — it must also be true to the source material. And, of course, you need the detailed positioning and situational awareness that lets you play your best.
- Vengeance 1300: Your sound card meets its match
- Intense, Immersive Gaming
- Superior Comfort
- Large 50mm Audio drivers
- In Line volume control
- High-sensitivity noise-cancelling microphone with flexible boom
- USB and analog connections for universal compatibility
- Two Year Warranty
Was £54.98 Inc. VAT
Only £48.98 inc VAT.
ORDER NOW
Corsair Hydro H60 High Performance Liquid CPU Cooler (Socket LGA2011/1366/1155/1156/775/AM2/AM3) (CWCH60) @ £49.99 inc VAT
nonl2br
The Corsair Hydro Series H60 is a fantastic choice for cooling. With a new micro-channel cold plate and a split-flow designed manifold, the H60 brings remarkable new technologies to an affordable price point. If that weren’t enough, the H60 also features an all-new fan, custom designed to offer enhanced static pressure, which means better cooling.<br>
You don’t have to sacrifice performance to build a quiet system. Most high-performance coolers use crude, outdated designs that rely on two techniques: put a huge hunk of metal in your case or crank the fan to obnoxiously loud noise levels. The Hydro Series coolers feature innovative, cutting-edge designs that utilize the superior thermal conductivity of liquid over air to provide fantastic cooling at much lower noise levels. In fact, the H60 is similar in noise levels to a 120mm case fan you probably already have.<br>
Almost any case with a rear 120mm fan mount location can house the Hydro Series H60 CPU cooler. And don’t worry about compatibility with your CPU, we’ve got you covered. AMD® sockets AM2 and AM3 are covered, and without having to install a custom backplate, making the H60 a great choice for any modern AMD CPU up to the new Phenom six-core processors. And when it comes to Intel®, don’t worry about it. Whether you’ve got Socket LGA775, LGA1155, LGA1156, or LGA1366, we’ve got compatibility inside the box. That’s right, even the brand new Core i5 and Core i7 2x00 series processors are supported, right out of the box.<br><br>
- Socket LGA2011/1366 / 1155 / 1156 / 775 / AM2 / AM3<br>
- Radiator Dimensions: 120mm x 152mm x 27mm<br>
- Fan Dimensions: 120mm x 25mm<br>
- Fan Speed: Up to 1700 RPM<br>
- Fan Airflow: 74.4 CFM<br>
- Fan dBA: 30.2 dBA<br>
- Fan Static Pressure: 3.2mm/H20<br>
- Cold Plate: Copper<br>
- Radiator Material: Aluminium<br>
<br>
<CENTER><IMG SRC="http://www.overclockersclub.com/siteimages/awards/OCC-Gold.png" height="150"/><CENTER><IMG SRC="http://images.hardwarecanucks.com/image/akg/water_cooling/H60/dam_good.jpg" height="150"/></CENTER>
<br>
<CENTER><iframe width="560" height="349" src="
" frameborder="0" allowfullscreen></iframe>
Was £56.99 Inc. VAT
Only £49.99 inc VAT.
ORDER NOW
How long are these deal prices running for? I really REALLY want the Corsair 550D, but the saving on the case has been undone for me by the Samsung Green ram going up over the weekend from £38.99 to £49.99.
If i had made enough posts on here for the free pnp I would have been ok! I keep waiting for the right combination of gear to go on offer that I want. Each week is so close! :-(
nice deals but just got my AX750 from you guys this morning (only ordered on Sat so was surprised when the delivery man turned up!) The box for this thing is huge though ;O
I've ordered mine. With a H100 cooler and Crucial M4 256Gb. All on offer so i ordered! Just waiting for the samsung green to drop in price, and a dvd-rw to go on offer. Then i have everything for my build
I ordered the 550d 2 days before these offers became live. Any chance i can have the £10 saving towards a future order. (before i open the box)
