- 23 Apr 2012
- Edinburgh
Anyone complaining about heat obviously hasn;t been around long enough to remember the old Athlons: http://www.phys.ncku.edu.tw/~htsu/humor/fry_egg.html
OK, here's the really important question for those who now have and Ivy bridge -
"Is it what you were hoping or would you have been happier with a Sandy bridge that runs much cooler."
It seems that 22nm just isn't quite ready yet. Needs s bit more Haswell.
It's about time AMD had some good news. I am sure they welcome some Ivy Bridge heat bashing.
It seems that 22nm just isn't quite ready yet. Needs s bit more polishing.
I know you meant it offhandedly but is seems others really perpetuate that thought more seriously. 22nm is ready, it delivers silicon which is more than viable it is just not as polished as the mature 32nm.
Intel sort off stabbed themselves in the foot with Sandy. They made it so good that unless your made of money or need new tech you won't need to upgrade for 3-5 years I think.
That would be an IVY running IBT.
I have just tried it on an i3750k and it went north of 100C almost instantly
Suspect other programs using the linpac binaries will do the same.
I am now using AVX enabled Prime95 v27.4 to test for stability instead.
It is nice to know your IBT stable but i'm not running it on the IB again.
Running both Prime and IBT at the same time, temps at 70*C
Just checking i follow the reasoning:
ibt runs the chip hotter than prime. Instead of lowering the overclock to deal with the inadequate cooling, the plan is not to run ibt?
That's a pretty lax definition of stable![]()
