Mine has the Z20LEH (VXR) Engine
Yup, Precise, Sharp and Direct. No understeer either![]()
I've never really understood all the negativity towards the Astra VXR, I enjoyed driving it on the VXR trackday.
Halfords spray paint about a fiver:
Just cooking them both for another 5min then going to wet sand them and laquer them. Should be spot on.
1 is brand new what is on the car.
Indeed, it's a good car imo.
Anybody else find it ironic that by far the best VXRs aren't really Vaxuhalls?![]()
Owned a Corsa VXR for a little over three years......
Was decent car to won overall. Fun to drive at time![]()
How did you find the reliability during your time of ownership?
I would say it was okay. Fun car to drive.
I purchased mine brand new and was fine until the engine went pop. When I tried to get Phoney Motorsport to fix it, they declined. So I got legal on them. Eventually the engine was replaced!
So I've had one new engine, radiator needed replacing as it was leaking coolant..... Ah also had to replace a brake caliper and hand brake cable.
Minus the engine issue the car was fine with me.
