Lower end Ivy cpus, any good?
21 Oct 2002
Bexhill on sea
As I was reading some reviews on the ivy cpus last night I noted they were all of the upper end procs, none of the lower end ones. The 3450 and 3550 cpus have not been reviewed by anyone as far as I could find using google. Now, I know they're not K cpus so I don't think they're multi unlocked, but I would assume they might hit 4.2, 4.5 ish when overclocked in the same way as you'd overclock an i5 750/ 760, up the fsb, drop the multi, and maybe up the v core a bit.
Now, considering the cost of these and what they "might" overclock to, they might offer an upgrade of sorts for ppl with, say, a high end Phenom II, or low end i5 750 sort of level, due to the cost, especially the 3450 at £145.
Opinions?
Hi there,
Unfortunately, with the LGA1155 CPUs you really can't change the BCLK very much - as so much is reliant on that bus. On the outside you may be able to get up to 110MHz (at the very most - most likely less), but it generally isn't recommended to push the BCLK on these CPUs.
The i5 non-K series do feature "limited" multiplier overclocking - but AFAIK it is only up to a maximum of 400MHz.
Cheers mate for the info, clarifies a lot I wasn't sure about (which is a lot :p). So these ivys and sandies can't have their "fsb" increased up to 200mhz like you can on the older i5 760 'frinstance? I assume its all done on the multi?
Exactly, the BCLK (which is effectively the FSB) is very locked-down on these CPUs and you can only change them by a few % before the system becomes unstable. As you say, basically all the overclocking is done via the multiplier.
Ok mate, thats my theory out the window then :D
I've just started looking at these chips and the i5 3450 could be a real corker...
Not many samples on cpubenchmark
http://www.cpubenchmark.net/cpu_lookup.php?cpu=Intel+Core+i5-3450+@+3.10GHz
But I can believe it being slightly faster than an i5 2500k at stock but the // CUT HERE boosted Quick Sync will blow the 2500k away. // No HD4000 :(
Grrrrrrrrrrrrrrrrr
Excitment dashed http://ark.intel.com/products/65511/Intel-Core-i5-3450-Processor-(6M-Cache-up-to-3_50-GHz)
HD2500 only and no VT-d - damn it
OcUK need to update the index page for IB processors ... This is clearly not a HD4000
http://www.overclockers.co.uk/productlist.php?groupid=701&catid=6&subid=567&sortby=priceAsc
