lol clecooooooooooooooooooo
OC'ing the cards will not reduce the life of cards. Not by an amount that you will ever notice at least.
ok, fine, you win on that one.
Antec spot cool aren't ideal for SLI set ups either, they are designed more for chipset/RAM cooling if anything.
What on earth is the point of overclocking if you already have the performance you want? It can add heat to your case henceforth making things noisier (fans will spin up further). If you have a steady 60FPS already with vsync on, what on Earth is the point in keeping a 24/7 OC on your HW if you won't see or notice ANY performance gain AT ALL.
There's no point in investing £100's into a watercooling loop
just to get overclocks which you will not notice. It makes no sense at all.
Don't get me wrong, OC'ing isn't pointless in every scenario, and i'm not just saying nobody should overclock, but the main advantage of overclocking, and the reason most people do it is because of performance gains. If you can't see any performance games or don't need anymore, then overclocking has been a waste of time for you. For example, i OC'd my CPU to 4.5 ghz but didn't see any visual difference, so, after posting about it on the internet to boost my epeen, i put it back to stock and got cooler temps on it.
Now, spotcools; yes, their original purpose was to cool chipset/RAM, but in the graphics card section, in many threads i see them being recommended by those who have multi card setups by the likes of Rroff and setter who have sworn by them improving temps in GTX 470 SLI. Just because something was designed for one purpose, doesn't mean it can't also be used very effectively for other purposes.
get out
with 17k posts you would understand that this is
www.overclockers.co.uk not
www.mehdontbother.co.uk
When did i say "meh don't bother?"
Re read my post and try to understand the full context before charging in to have a go at me.
I said:
Cleeecooo said:
I wouldn't OC unless you NEED the performance gain.
Go on then. Explain to me, Cupra, why else someone would overclock bar for epeen reasons?
thanks Cleeecooo, i appreciate your advice. i have a p8z68 motherboard and the 3rd slot only runs at 4x i believe. would this penalise sli performance much?
not sure about that i'm afraid, why not just try it and see?
i rushed into buying those cards without too much research, with the intention of playing bf3 in nvidia surround on my 3xhazros! i get 1-2 fps on ultra!! i think its mainly due to them being 1.5gb ram cards, so i will take any performance increase i can get by overclocking them, although i don't think my dream will ever become a reality as far as hi-res, triple-screen, surround action is concerned!
I very much doubt Oc'ing will increase your FPS from 2 to 30+
You should go and post on mumsnet to be frank
, don't overclock pfff
They keep banning me for speaking the truth on mumsnet
Stupid cows lol
I never said don't overclock, I just said don't do it if it's not going to help you at all or give you any noticeable gains.
