** NEW EDIMAX Networking Hardware **
  • Thread starter Thread starter rjk
  • Start date Start date
rjk
rjk
OcUK Staff
8 Aug 2007
Hi Guys
We have some superb new products from Edimax that are in stock now and ready to ship.
Presenting great value along with rich feature sets, each product in our range is designed to offer brilliant performance at great pricing.
Be sure to check out the EW-7612PINV2 as well. This is a real stand out product for anyone looking for PCIe Wireless at a superb price point.
Edimax EW-7733UND N750 Selectable Dual Band USB Adapter @ £29.99 inc VAT
Enjoying high-speed, dual-band (2.4GHz & 5GHz) wireless connectivity is as simple as plugging the Edimax EW-7733UnD into your computer’s USB port. This wireless dual-band USB adapter is a quick and easy way to add wireless connectivity to or upgrade the wireless connectivity of your desktop or laptop computer. Its flippable antenna design also allows you adjust the antenna for optimal Wi-Fi performance.
Dual-Band Wireless Connectivity (2.4GHz & 5GHz)
Designed in compliance with 802.11a/b/g/n standards, the Edimax EW-7733UnD is able to connect to devices that use the 2.4GHz band as well as devices that use the 5GHz band. With dual-band capability, the EW-7733UnD gives you full flexibility in terms of device interoperability.
Wireless 802.11n Standard (data rates up to 450Mbps)
The latest 802.11n technology is built into the EW-7733UnD to broaden its wireless coverage by 6 times and to reduce dead spots within the wireless range. The EW-7733UnD complies with wireless 802.11b/g/n standards and can reach data transmission rates of up to 450Mbps when connected to wireless 802.11n devices. It provides faster and more reliable wireless connections than standard 802.11b/g wireless networks.
Flippable Antenna Design
The EW-7733UnD is designed with a flippable antenna, allowing you to adjust the antenna’s angle for optimum Wi-Fi performance. Folding back the antenna also allows for easy antenna storage when it is not in use.
Features a Hardware WPS (Wi-Fi Protected Setup) Button
Wi-Fi Protected Setup (WPS) is a standard for easy and secure establishment of wireless networks. If the wireless device with which you wish to connect supports WPS, the Edimax EW-7733UnD will automatically set up the wireless connection with a robust WPA data encryption. The Edimax EW-7733UnD wireless USB adapter supports both hardware (push-button) WPS and software WPS configuration.
Features Multi-Language EZmax Setup Wizard*
The Edimax EW-7733UnD includes an EZmax setup wizard—an application available in 18 languages that helps you to quickly connect the adapter to your wireless network.
Only £29.99 inc VAT.
ORDER NOW
Edimax BR-6675ND N750 Concurrent Dual Band Gigabit Cable Router @ £76.99 inc VAT
Concurrent Dual-Band Wi-Fi & Gigabit Ethernet Connectivity
The Edimax BR-6675nD iQ router provides simultaneous 2.4GHz and 5GHz wireless network connectivity for maximum flexibility of use. This router allows users to use general network applications like web surfing via the 2.4GHz bandwidth and stream HD video and other media through the 5GHz bandwidth at the same time. Additionally, the BR-6675nD iQ router features 1 gigabit WAN port and 4 gigabit LAN ports, offering users with the need for maximum network performance data rates of up to a staggering 1000Mbps. With gigabit Ethernet connectivity, the BR-6675nD can provide users a fast and smooth media streaming or network gaming experience.
Edimax’s Revolutionary iQoS
The revolutionary iQoS is Edimax’s answer to the need for a quicker, easier, and more effective way to manage Internet bandwidth. Most routers on the market feature QoS (Quality of Service) functionality, but the problem with this feature is that only advanced users know how to set it up. That is why Edimax has redesigned this feature to make it extremely user-friendly. Its simple and intuitive user interface allows users to arrange bandwidth priority settings in just a few clicks. With iQoS, gaming, video streaming, using VoIP applications and BT clients at the same time will no longer be a nightmare*. iQoS is no doubt the best guardian of your Internet bandwidth.
The Edimax BR-6675nD is a high-speed solution that complies with IEEE 802.11a/b/g/n standards. The latest wireless technology is built into this iQ router to broaden its wireless coverage by 6 times and to reduce dead spots within the wireless range. When it is connected to wireless 802.11n compatible devices, the BR-6675nD can achieve transmission rates of up to 450Mbps.
WPS (Wi-Fi Protected Setup) Button & Built-In WLAN On/Off Switch
The Edimax BR-6675nD allows users to build secure connections with WPS enabled wireless devices simply by pressing the WPS button. There is no need to go through the hassle of setting up and configuring the security of your wireless network. With the built-in WLAN on/off switch, users can also easily switch on/off the wireless connection without logging into the user interface. The WLAN on/off switch provides users an easy way to save electricity by switching the Wi-Fi signal off when it is not in use.
Only £76.99 inc VAT.
ORDER NOW
Edimax BR-6258N N150 Nano Range Extender/Cable Router Black @ £28.99 inc VAT
Miniature, Energy-Efficient, Space-Saving, and Stylish
The BR-6258n is a miniature, energy-efficient, and space-saving wireless broadband router that is designed with pure stylishness. But this stylish router is not just about the looks, it has all the features that make it versatile and an extraordinary performer.
True Flexibility and Convenience
With both a WAN port and a LAN port, the BR-6258n gives users the flexibility of using it as either a router or a wireless adapter. The true convenience of the design lies in that the user only needs to make the appropriate cable connections and the BR-6258n will switch between the two modes automatically.
It’s as Fast as It Looks
The EDIMAX BR-6258n complies with IEEE 802.11b/g/n standards. Its wireless data transmission rate can reach up to 150Mbps and its signal coverage is 3 times greater than standard 802.11g/b routers.
The BR-6258n has a built-in WPS button, which allows users to build a secure connection with a wireless network client with a simple click. There is no need to go through the hassle of configuring the complicated security settings manually.
IP Sharing, Virtual Server and DMZ
The NAT/NAPT function lets you share the Internet connection with up to 253 Intranet users. The virtual server and virtual DMZ functions also allow your internal servers to be accessed from the Internet.
Only £28.99 inc VAT.
ORDER NOW
Edimax BR-6428Ns N300 300Mbps Cable Broadband Router @ £23.99 inc VAT
Green Technology
The EDIMAX BR-6428nS is designed with the latest green technology. By detecting the amount of wireless transference and supplying only the amount of power needed, this router is able to ensure the highest wireless performance while saving up to 66% of the usual power consumption. Even when it is in full loading, the BR-6428nS uses 50% less power compared to other non-green 300Mbps routers.
Wireless 802.11n Standard (data rates up to 300Mbps)
The EDIMAX BR-6428nS is a high-speed solution that complies with IEEE 802.11b/g/n standards. The latest wireless technology is built into this router to broaden its wireless coverage by 5 times. When it is connected to other 802.11n devices, the BR-6428nS can achieve transmission rates of up to 300Mbps. With such performance at such a competitive price, the BR-6428nS is truly the most cost-effective solution for any home or small business environment.
Shares a Single Internet Connection with up to 253 Clients
With NAT (Network Address Translation) capability, the EDIMAX BR-6428nS allows up to 253 wired or wireless clients to access a single Internet connection simultaneously.
Flexible WISP ( Wireless Internet Service Provider) Connection Mode
With WISP support, the BR-6428nS is able to access the Internet wirelessly from an ISP access point and turn it into a wired or wireless network for multiple users in your home or office.
Easy Setup with EZmax Multi-Language Wizard*
In addition to the built-in, multi-language user interface, a unique EZmax multi-language setup wizard is included in the installation CD. The animated and easy-to-follow instructions will guide you through the setup process and allow you to set up the router within minutes.
The EDIMAX BR-6428nS has a one-click WPS (Wi-Fi Protected Setup) button to help you set up and activate a secure wireless network in a snap.
Only £23.99 inc VAT.
ORDER NOW
Edimax EW-7612PINV2 300Mbps Wireless-N Network Adapter - PCI Express @ £16.99 inc VAT
EW-7612PIn is a wireless PCI Express adapter that provides a simple and easy way to add or upgrade wireless connectivity to your desktop. This wireless PCI Express adapter supports higher data rates up to 300Mpbs when connected to a wireless 802.11n device. You can also connect to any public wireless hotspot for Internet access to retrieve email, surf web sites or use instant messaging. EW-7612PIn gives you the freedom to join the network.
Complies with wireless 802.11b/g/n standards with data rates up to 300Mbps
With the latest wireless 802.11n technology, EW-7612PIn can increase coverage up to 4 times more and reduce "dead spots" within the wireless range. The transmission data rate can reach up to 300Mbps when connected to wireless 802.11n devices, making signals travel farther and wireless connections guaranteed when compared to a standard wireless 802.11b/g network.
First-class Reliability
The EW-7612PIn’s exceptional chipset offers increased bandwidth and more functionality than other standard PCI network adapters. The adapter is specifically designed to carry the full bandwidth capacity of the PCI Express bus of 2.5Gpbs, thus eliminating collisions and latencies that exist with current 32- and 64-bit PCI bus architectures.
Wireless Security
EW-7612PIn supports 64-/128-bit WEP data encryption that protects your wireless network from eavesdropping. It also supports WPA (Wi-Fi Protected Access) features that combine IEEE 802.1x and TKIP (Temporal Key Integrity Protocol) technologies. Furthermore, this adapter supports WPA2 and WPS functions, with WPA2 providing a stronger encryption mechanism through AES (Advanced Encryption Standard), which is a requirement for some corporate and government users. Wi-Fi Protected Setup (WPS) is a standard for easy and secure establishment of a wireless network. EW-7612PIn supports software with WPS-compatible configurations. When both ends of the wireless connection use wireless solutions with WPS, it automatically configures the wireless network with robust WPA data encryption and authentication.
Supports multi-language EZmax setup wizard
The included 16-language EZmax setup wizard and friendly UI will walk you through configuring EW-7612PIn to your wireless network.
• Complies with wireless 802.11b/g/n standards with data rates up to 300Mbps
• Increases wireless coverage 4 times farther?
• Built in 3dBi high-gain detachable antennas
• Includes multi-language EZmax setup wizard
• Supports 64-/128-bit WEP, WPA , WPA2 encryptions and WPS-compatibilities
Only £16.99 inc VAT.
ORDER NOW
EW-7612PIn
Any idea how much actual real world throughput i'd get with that? Obviously I am not expecting 300mbit, but 100mbit would be nice.
I am using an RT-N56U router.
EW-7612PIn
Depends on how far away you are and what's in the way of the line of sight (walls etc).
