- The clutch is on its way out.
- Recently I've found the exhaust is "blowing" and has a hole in it.
- Recently the car has developed a tendency to make clunking noises when turning. I suspect it's either/combination of the CV joints/track rod ends/suspension. I'm going to get it on to axle stands to have a proper look.
- The oddometer has started to cut out randomly.Google suggests the speed sensor in the gear box needs replacing.
What makes you think buying a £1k car is going to stop this being an issue on whatever you get next?
