Gigabyte Z77X UD3H
17 Aug 2009
Finchley, London
Still undecided if I'm getting Ivybridge 3570K or Sandybridge 2550K. I do like the features of this motherboard,
http://www.overclockers.co.uk/showproduct.php?prodid=MB-389-GI&groupid=701&catid=5&subcat=
is it worth buying if I don't get Ivybridge, perhaps for futureproofing like changing to IvyBridge from Sandybridge at some point later on? With Sandybridge installed, would I be missing any must have features that the board is capable of with Ivy?
The UD3H has something like 6 power phases and the UD5H has 12 I believe. Does this mean that the UD3H would overheat more easily while overclocking? What about the audio chip, it's not realtek but VIA. Any good? The spec for it seems about the same as realtek.
Hi i have one, been running it a few days now with my IVY 3570k, its very nice like most gigabyte's boards.
Easy to work with, overclocking seems very simple, running at 4.2 on 1.164volts hottest core on load hits about 55 on air, the below cooler with an apache fan
http://www.overclockers.co.uk/showproduct.php?prodid=HS-047-ZA&groupid=701&catid=57&subcat=1395
With a silent system im happy with the clock, it could go more but i dont need to. It ticks all the boxes to be honest.
the only thing from you list is the audio chip, i came from a X-FI but due to crossfire i cannot fit the card, so for now run the onboard sound, its ok, but defo not as good as the X-Fi i had. If your on on-board now then i would guess its as good, i will pick up a cheap PCI-E sound card thinking this,
http://www.overclockers.co.uk/showproduct.php?prodid=SC-015-AS&groupid=701&catid=11&subcat=
Hope it helps
Thanks guys. Well I've got an old soundblaster 5.1 knocking around somewhere, lol. But I much prefer the convenience of onboard sound. I've found the realtek built into my old gigabyte motherboard to have nice sound quality, it's the Realtek ALC888 8-channel audio codec. If the Via VT2021 is comparable, then it would be fine.
http://www.hardwaresecrets.com/article/Audio-Codec-Comparison-Table/520/1
Thats a list of codecs and specs, so you can compare the VIA against Realtek.
Thank for that. Looks like the VIA is at least as good as mine and even slightly better.
I'm running one, nice board but can't comment on the sound as I use a xonar dg. Easy to OC on and the bios is nice. Spot on for the money and if the sound is poor you could buy a cheap xonar or x-fi
Yeah and you could always try out a PCI-E Sound card if you ever feel you want better sound or even just to see the difference, as long as you don't destroy the packing you could probably just return it to the shop if you don't see much of a difference.
Nice board Merlin5, also having Gigabytes customer service there if you need it is a bonus:)
