As has been mentioned there is no perfect solution unless you go agua.
All the coolers have so much depth you cannot fit High profile ram unless you raise the fans, except the Armageddon but then that is so wide it takes up the 1st PCIe slot.
H100 does the job I'm looking forward to something that can take it to the next level though in the category it competes in, and I'd be willing to pay substantially more for performance gains.
