Whilst your opinion might have some merit, The Halk is pointing you in the direction of the various comments regarding the validity of certain terms and conditions. If you had read the whole thread you may have learnt that (a) the T&C hold specific provision for the waiver of the prohibition of items and, by accepting the item as described, it is arguable that the waiver has been put into effect; (b) the references to no compensation are irrelevant since they appear solely within a document described as "a rough guide" and points the customer to the full T&C; (c) the T&C themselves bear no reference whatsoever to the avoidance of compensation payments regarding otherwise excluded items accepted pursuant to clause 4.2 of the T&C; (d) regardless of anything else, any term that attempts to limit the liability of an organisation through damage or loss caused through their own negligence, or indeed simply creates any type of unfair bias in favour of a supplier against a consumer, is likely to be deemed unfair, causing it to be unlawful and would, therefore, be set aside if the matter were to reach court.
