Corsair H60 noise?
10 Sep 2009
United Kingdom
I recently brought a Corsair H60 for my build with i5 2400, 8gb low profile ram and a h61 mobo. It keeps cpu really cool, around 40c max load. But I find the pump of the H60 significantly louder than the H50 that I am using for my other computer.
Do anyone else have similar problem or is it really that much louder than the H50?
i've read about this problem, susposley if you press down on the pump and the noise stops, it's faulty. +1@cowello, find youtube video of faulty h60's and compare the sounds coming from the pump.
may i ask for personal interest, what cpu are you using & if it's overclocked & finally are you using the standard h60 setup as in their fan & radiator?
