Please help with my gaming build
28 Apr 2012
Hey guys,
I've been doing a fair bit of research into some good bang-for-buck components to build a PC, primarily for gaming. I'm kinda trying not to waste money for minimal returns at least.
So far I have this list. If you can find anything wrong with it, or something that should be definitely changed, I'd be happy for suggestions:
Mobo:
£110 - ASRock Z77 Extreme 4 S1155 Intel Z77
^ I chose this mobo as it was relatively cheaper than other Mobos that have USB 3.0 front panel connectors (for my case choice below) while also supporting both SLI/Xfire for future potential. Seems well reviewed, seem ok?
£40 - G-Skill 8GB (2x4GB) DDR3 1600Mhz RipjawsX Memory Kit CL9 (9-9-9-24) 1.5V
^ Seems a fairly standard choice. Will this be compatible with my motherboard choice? Quite the PC builder newbie here.
£157 - i5 2500K sandy bridge (unlocked)
^ This seems the most common choice, with the i7 being around £240+. I don't know if the i7 is really worth the extra cost for the purpose of gaming for me? No idea whether Ivy Bridge are worth it either, any suggestions whether this will be decent enough for gaming? Thoughts?
£28.50 - Cooler Master Hyper 212 EVO processor cooler
^ Seems another common choice. Decent enough? Compatible with my mobo/processor?
£200 - EVGA GeForce GTX 570 HD 1280MB GDDR5 (012-P3-1571-KR)
^ Ok, so I went through much deliberation to come to this. Basically, I initially was thinking about the GTX 480 which is only marginally less powerful and is around £165. But given that seems to have overheating/noise issues, I opted to go for this. I think it should work well enough, and it is one of the top performing graphics cards out there at the moment. Thoughts?
£89 - Crucial 128GB M4 SSD
^ Yeah, I'm a sucker for the thought of having a faster booting OS. I've heard 60GB can get used up quite quickly and those models are slower, and the 128GB wasn't too much more costly. This model seemed to have better reliability looking at reviews on newegg and the like than the OCZ agility ones. Although it does have a lower write speed, I'd be more interested in reliability.
£72.70- Corsair CMPSU-700GUK Gaming Series GS700 High Performance 700W Power Supply
^ Had a look around for this, I thought 700W would be more than enough for my current build but with the potential for SLI at a later date. Do you think that would be enough, or should I go higher than the 700W? (It is 80plus)
£55 - Antec 300 two case with usb 3.0
^ Was impressed with this case with it having good airflow and the front USB 3.0 ports. Seems like a good case for the value too.
So far clocks in at about £750. What do you guys think? If you have any alternative suggestions can you find them on UK websites? Or perhaps cheaper alternatives (or cheaper places to buy the components) would be awesome.
Thanks guys!
Welcome, Firstly, id edit your post quickly, you are not allowed competior links or names.
After that, we can help you. Just name the parts and state the price.
Thanks
Just be careful of the RAM you get with any aftermarket coolers. Any reason your going Sandybridge over Ivybridge? also any reason for the GTX 570 over a 7850? They are apparently better value for money and have good overclocking potential as well.
Thanks for the help.
The reason for the 2500K is that it seems (from what I've read) to run a lot cooler, which I like since it means I could have fans at lower power and have less noise. It doesn't seem all that worse for a gaming ring. And also it seems to be a lot easier to overclock, and many people seem to be happy getting it to around 4.8+. I've got the impression that people haven't been that impressed with IB whereas the 2500K I've heard nothing but good things.
The Radeon 7850...I see from google this runs on lower power. Is the performance not too much lower than the GTX 570? From benchmarks the 570 seems to outdo it.
True, the 2500k get better overclocks but the ivy's improve on sandyrigde (overall) by a few %. So its just a personal choice. They are the same price aswell and with the performance being simular......
The 7850 is low power, yes and at stock it's a tad off the 570's pace but the 78**'s overclock really well and the performance of them is great. The 2GB VRAM is also very helpful.
I have my fans on the lowest setting Overclocking my 3770k it makes little to no difference to my temps (my heatsink is pretty quiet not sure what speed it's running though) Im planning to get some more fans however to get a lot more air flowing in my case. Personally I would go 3570k even though it generates more heat you won't even use a 4.6Ghz clock on it anyway.
