Gigabyte GA-Z77-UD5H - Where is speedstep?
28 Oct 2011
I cant find speedstepping anywhere in the BIOS, but something is adjusting my Multiplier and voltage in realtime. :s - am I missing something?
Why not leave it on? These days it rarely causes problems and reduces idle power consumption, temps etc. Often guides give this dated advice to disable it to help with overclocking but frankly for non extreme overclocking it won't make any difference.
Either way it should be under M.I.T > Advanced Frequency Settings > Advanced CPU Core Features > CPU EIST Function.
C1E is multi control i think.
C1E enhanced halt state — Introduced in the Pentium 4 500J-series processors, the C1E halt state replaces the old C1 halt state used on the Pentium 4 and most other x86 CPUs. The C1 halt state is invoked when the operating system's idle process issues a HLT command. (Windows does this constantly when not under a full load.) Entering halt state, which is a lower-power state, will cut a CPU's power consumption and heat production. Intel's new C1E halt state is also invoked by the HLT command, but it turns down the entire CPU's clock frequency (via multiplier control) and voltage in order to work its mojo. This more robust halt state requires significantly less power than the old C1 implementation.
C1E halt cranks the CPU bus multiplier down to its lowest possible level on the 600-series processors, which is 14X, so a P4 660 processor with the C1E halt state active actually runs at 2.8GHz. I believe that C1E halt is also a binary condition invoked by the HLT command; it's either on or it's off.
Enhanced SpeedStep — SpeedStep also modulates the CPU clock speed and voltage according to load, but it is invoked via another mechanism. The operating system must be aware of SpeedStep, as must the system BIOS, and then the OS can request frequency changes via ACPI. SpeedStep is more granular than C1E halt, because it offers multiple rungs up and down the ladder between the maximum and minimum CPU multiplier and voltage levels.
Intel cites its mobile products when talking about SpeedStep, which is apt but not entirely helpful because it conjures up images of the Pentium M processor, a very different beast. The Pentium 4 doesn't contain most of the heroic power-saving measures of the Pentium M.
