Yup, the stock benchmarks Azza posted earlier are very impressive, theyre very slightly below my sli'd 470's on a very heavy 800mhz core clock. Seen a few users on here killing x58 motherboards with high clocked fermi cards, mainly gtx 470's.
I think the real question in this thread now is 2 X 670's or 1 X 690.
i'd love two 7970s but unfortunately i dont trust the drivers... because when you do the research, it's Crossfire that's screwed
that card has 4gb of VRAM so 8gb in total and 4gb is usable
I like the way you keep talking about "research" on every thread when what you actually mean is "I googled and found some forums posts that I have no way of checking if they are true or not"
you crack me right up
Sorry I had a 690 link open already I thought that's what he posted. If you have the room and extra cash to fork out for 4GB 680's then that's what I'd get. A lot of new games come out that are only initially ready for single cards and you could be waiting ages for a fix for SLI. I'm not sure you can disable one chip on a dual-GPU card, someone else will have to fill you in.
deffo 2 x 670s...... 690 is a waste of time, it doesn't have enough Vram to make it future proof..... the 690 would have been the one to go for if it had 3 to 4 gb Vram per card..... it might be ok though, but you just cant tell what's around the corner
mine is not installed yetbut i'll keep you posted, because i have to see if my new rig works first, so i'm sending it into the shop soon, i'm not sure if it's wired up correctly/ or if the CPU is dead after i've lapped it.... i've messed around with it quite a lot! ... i'll get the experts to fix all the niggles first otherwise this will drive me crazy, plus i need them to transfer all my Steam files over from my old rig
OC seems to be about 1.3V...GPU 1280mhz.....Mem 1860mhz, but i doubt i'll need it as high as this.
i researched this card quite a lot, if it has bad coil whine you can cure it by painting the coils/ capacitors with gloss varnish, i used to do this for a living... you can easily varnish the whole card it doesn't halm it at all, just dont get it into the sockets etc or on the GPU.
you can spill it onto the rear face of the card, let it run around the rear area and then let it drain off, just dont use the card for a day, let it dry out totally, this will cure the whine.
i'm very impressed with the fan blades, they look even better than my Xigmateks, very shiny finish to them
^this, would be interested to know if you could disable sli on dual cards anyone? i am considering 2 680's myself and being able to just run one card when needed is a must.
Advice from a man who has experience....
Don't blame you given these benchmarks. 670 totally spanks the 7950!
this is a well known question mark over the 690 and the 680 too, ( the lack of Vram) if you want to bitch at me like a silly child do it via ``Trust``, not on the forum
Well known? I must have missed all this then as even multi monitor set ups are doing nicely with 2GB of vram.
