Buck do you have LLC on the highest setting or disabled? having it disabled makes being stable at lower volts a lot easier tbh.
at highest setting atm - haven'[t thought about lowering it - which mobo are you on ? I'm on a MVG
its amazing that 2 tiny tiny volts adjustments can have a 10C delta difference i temps
PLL volts seems to have a good difference too (I think I'm on 1.6 manual vs 1.85 Auto ...)
my MVG sets a substantial offset voltage for IGPU - I think 0.15V .. I reduced this to 0.05 but not sure why its over-volting gpu or whether it effects clocks/temps
