Hi all
I wish to extract some ideas/thoughts from your watercooling junkies
Plan;
1. X79 socket 2011 setup with 2 x 680s
2. Wish to run both on separate loops
3. 680s on one loop and CPU on another
4. Cosmos 2 case - the big heavy one
5. I wish to use 360 ran on top for GPUs
6. I wish to use 240 rad for CPU located at bottom
7. I would prefer front mounted bay res'
Questions;
1. Do I need a dual bay res for the GPUs for single for the CPUs
2. What pumps are best?
3. Is two loops overkill? Or needed for maximum overclocking?
4. Tube size? 1/2 or 3/8. What is the deal with barbs etc?
No lighting or nonsense needed.
Just ideas at present and will reshape depending on your feedback
Thanks all!!
Plan;
Questions;
Thanks all!!
