Mate as others said you should just get yourself the Z77 and be done with it. It will be plenty and then some for your gaming needs. Also I was in a similar dilemma a month ago considering X78 Sabertooth against the Z77 Sabertooth. From all accounts i was getting is that for gaming and even general use like video editing the Z77 IB is still plenty without spending a lot more for what wont be much difference. Sure the 2011 socket CPU looks a beast but the lower ones arent even as good as the good socket 1155 CPUs eg. http://www.anandtech.com/bench/Product/523?vs=551 Also bare in mind that is at stock speeds 3.6ghz v 3.5ghz, The IvyBridge will overlook much higher.
If i was you Id consider the Z77 Sabertooth with a 3770K. Oh and you definitely want an SSD as boot drive it's a no brainer when building a computer nowdays, prices have come down a fair bit. Mechanical HDD will give you a WEI score of 5.9 out of 7.9... Good SSD will get the full 7.9 score and that particular bottleneck will be no more. So if you change the X79 to Z77 that will free up a lot of cash for the SSD.. maybe the nice Intel one.
Hope my input helps as i said i was going to get the X79 but now im saving for the Z77 with the best CPU it can take. One thing i dont get is im also after the H100 cooler and on OcUK it is cheaper than the H80.. cheaper single rad to a double rad? Anyone can shed some light on this would be appreciated
I think th H100 is on offer
yer, thanks Shaolin, I do take this into account, however I want the LGA2011 chipset because that way i can get the ivy-E and i really want to get a six core in the future for possible editing, and because i am an enthusiast.
does it say what cooler he is using?
