New Extreme Water Cooled Gaming rig build thoughts/comments?
23 Apr 2008
Hi Chaps,
Looking to do a major upgrade, got the basket below in mind and would like to see peoples thoughts on the set-up. Does any one aware of any major limitations with twining the 690's? Anyone used this setup in this case and had any space issues at all?
This is a permanent x3 monitor (24" 5760x 1200) for gaming - looking for max performance with BF3 / Crysis etc.
Thanks in advance.
The build:
  • EVGA GeForce GTX 690 4096MB PCI-Express GDDR5 Graphics Card
  • Intel Core i7-3930K 3.20GHz (Sandybridge-E) Socket LGA2011 Processor - Retail
  • Asus Rampage IV Extreme Intel X79 (Socket 2011) DDR3 Motherboard
  • Team Xtreem 16GB (4x4GB) DDR3 PC3-20800C10 2600MHz Dual/Quad Channel Kit
  • BitFenix Shinobi XL Full Tower Gaming Case - Black
  • Alphacool Laing D5 Vario Pump 655 - NO TOP
  • Hardware Labs Black ICE Radiator SR1 360
  • EK Supreme HF CPU Waterblock - Copper Plexi
  • Hardware Labs Black ICE Radiator SR1 120
  • EK Multioption Reservoir X2 250 Advanced
  • Alphacool HF D5 TOP - Black Acetal G1/4
  • XSPC RayStorm Intel Aluminium Bracket
  • Arctic Silver 5 Thermal Compound (3.5g)
  • OcUK Tube Cutter Aluminum 3-14mm
  • Arctic Silver ArctiClean Thermal Material Remover and Surface Purifier - 60ml Kit
  • XSPC HighFlex Hose 7/16" ID, 5/8" OD, 15.9/11.1mm, 2m, Clear
  • Mayhems Ultra Pure H20 Watercooling Fluid 1L
  • EK-PSC Adapter Rotary 45° G1/4 Nickel
  • EK-PSC Adapter Rotary 90° G1/4 Nickel
  • OcUK 1/2" G1/4 - FatBoy Style - Black Nickel - Barb Fitting
I'd say get either the TJ-07 or the 800D to have sufficient space for cooling. The TJ-07 can take a quad radiator and a dual radiator for example.
