CASES WITH BUILT-IN WATER COOLING
8 Mar 2011
I wasnt sure where to ask this question but since its really to do with water cooling, Id thought I ask it here (so apologies to mods if its in the wrong forum)
Can anyone recommend a built in water cooling case please
A big enough one now
brilliant
I presume the watercooling in that system is for cpu and GPU
Can it do 2 gpu's ?
I think it only comes with cpu block, to be honest you would be better to buy all your required parts and build it you self, it's fairly straight forward and can save you some money sometimes, but for 2 570 blocks is the best part of £150-£160, plus also check before buying that the water blocks are available to buy as they seem to go out of stock quickly and hardly ever make a return, it is impossible to buy a block for a 480 in the UK.
