Can I butt in here, I have a 750W Hale90 Gold Rated. I'm getting my 560TI in the morning so will be doing SLI, I know it will be enough power but what will I have left for overclocking CPU/GPU, atm my i7 is at 4.4Ghz. Will I have to turn it to stock?
You will have more than enough power on a 750w PSU for your 560Ti in Sli
and your overclock on the processor as well, the Gfx cards don't use as much
as you would typically think under load.
There are PSU calculators that will tell you a ball point figure about how much
you will be using but i can't link them to you at the minute as im at work on
a night shift and cant access the the site from google to past the link on here.
Sorry for the double post. How much overclocking headroom will I have with my PSU and 560TIs, I have my CPU at 4.5Ghz atm but will I be able to overclock the two 560s or will that be to far?
eForce GTX 560 Ti in 2-way SLI
A second card requires you to add another ~175 Watts. You need a 700+ Watt power supply unit if you use it in a high-end system (800+ to a KiloWatt is recommended if you plan on any overclocking).
Will it be safe to push? Whats will happen if I go to far and end up trying to draw to much from the PSU?
